just got pinned today... :P
i can get the RWC part sorted (ride height, seat belt retractors and non padded steering wheel, afaik - still waitin on letter) but its the EPA i'm worried about... copper didn't say if it was a full test or just exhaust vol and i was WAAAAAAY too scared to ask him as he was in a FOUL mood when he pulled me over.
i have an aftermarket turbo (not highflow but lowmount) / ecu / injectors / fuel pump / BC / exhaust etc
if its a full test and i just put on the stock zorst from the dump or cat back and change out the ecu for the stocker am i gonna pass or are they going to look @ the turbo and simply say no way?
i'd MUUUUCH rather not have to go changing out turbo's as its only been in a week! :)
If you get the full test you will need to remove ecu/inj/turbo & bc. If the pump is just an in tank you will be fine. You might even be ok with a big one in the boot or similar, I never had my boot opened the 4 times I have been.
They will see the colour of you injectors is not normal and you will fail, they will see your shiny HKS heat shield and turbo (yeah they look that closely) and you will fail, they will check your ecu and you will fail.
To answer your question R34 NRG you roll up into a little booth and they visually inspect the car (engine bay, exhaust setup, etc) they will take notes on your setup incase you re-offend. They then stick a probe up your exhaust and do some emission testing (not 100% sure what they do here) I never had a problem with this section.
Then you move you car out to an open space where they test noise. Basically placing a microphone about 1.5m away from the exhasut tip and reving your car to 3/4 (from memory, might be more or less) of the rev range. You must be under 90db.
They then slap a green defect like sticker on if you fail and tell you you have 28 days to fix it otherwise your rego will be suspended, you cant sell the car in this time either (but it can be driven any time).
If you pass you go on your way and pray you never return
I would advise you are very polite and dont try to lie to them, they really know their sh*t.
G'day,
I have one question regarding tyres.
Would road legal semi-slicks such as Bridgestone Re55 pass RWC providing there's decent tread?
Or i'd be better off using radials?
Cheers
Grant
just hoping he didnt bother.... he left in a better mood than when he started (gool ol-fashioned citizen to officer felatio) and left a few things he mentioned off the canary...
*crosses fingers...moreso*
im on the new p plate laws with no engine modifications that increase performance.
would i get away with a lightened flywheel?
They will never find out. But a lighter flywheel wont increase power anyway.
Im on my green P's right.. got a r32 gts-t with fmic/pod/bc/turbo back exhaust..
now i know they can get me on the high powered laws if they knew i had the turbo back exhaust and bc.. but can they get me for having the fmic and pod? because stock the car is under the power to weight ratio but if i got rid of the BC and just had a fmic and pod i know they can defect me for having them both.. but can they say my car is high powered because ive modified it and those mods could increase the power?
So what can I do to prove its not.. dyno it and have the sheet's ready if the cop's pull me over to say here are the specific spec's for my car its under the power-to-weight ratio? but then they can say u couldve done that before the dyno etc..
I know the FMIC/POD is illegal for EPA but whethere i get EPA'd or Defected its no big fuss to get rid of the pod.. I was thinking if i get a heatshield made or a sheet or metal covering the pod, i know it wont help me on the EPA side of things but legal wise would it considering the cops wouldnt be able to see it? Or maybe even see if i can get someone to do a custom job with my stock airbox to fit over the pod so you cant see it?
It wouldnt be such an issue if i could fit the airbox in there but apparently where i took it they said theres no room for the airbox, only the POD.. so im not really sure what to do i want to make it look as stock as possible under the bonnet and as legal as it can be til i get off my P's..
From my knowledge, the majority of the time they will go off factory power to weight figures to determin if its oevr what it should be.
If situations where its modded they probably wont accept a dyno sheet from you proving the power, rather they will just tell you to return it to stock or rather epa/defect you for everything under the sun they can find :blink:
wtf a cop pulled me over and could find nothing defect me for and end up major defecting my s2 r33 which is stock height for being to low by .5mm. is there anything i can do to appeal it or should i just get a rwc and clear it
If situations where its modded they probably wont accept a dyno sheet from you proving the power, rather they will just tell you to return it to stock or rather epa/defect you for everything under the sun they can find :(
Under the bonnet my car isnt heavily modded.. Just fmic/pod, blocked off BOV which i need to unblock, stock plumb back is on there, and im gonna get my SSQV welded near the REO. Also got the R33 turbo but im sure they couldnt figure out that i've changed the turbo. oh and BC but im gonna get a new one installed hidden. But coz of the blue paint job and black bonnet i got now it looks really flashy.. Before i got the car painted i had never been pulled over with my car.. 1 week after the paint job and i get pulled over lol
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
