i just got epa letter in the mail for sound levels on the car now im just wondering when i go to get it tested do i only have to worry about the exhust noise or what about the turbo flutter, fmic and pod filter?
so XY GTHO's get left alone
icic
G'day all,
I'm in need of a place that does RWC near Frankston (couple of places has tried to rip me off), happy to drive to Moorabbin or Dandenong. Anyone decent would be nice...
Racepace :down: just k/d
just a question, i was at the warrigal rd and north rd intersection lights turnging right onto north rd and i accidently went through the red light and i got flashed but then i thought about it and it flashed as the car is turned on side so would it have only taken the picture from the side of my car of can they somehow get the back of the car?
nah its a emissions test aswel so there going to be checking turbo frontmount pod boost controler etc im just wondering will they say anything about that ive grounded my stock boost solonoid
Hey everyone
I have 18" Gmax enigma rims on my r32 gts-4 they are 8" wide and they have 235/40 R18 tyres on them.
I was defected for having bald tyres.
I went to vicroads to clear the defect and they told me that my tyres and rims are too big for my car. They said that the largest tyres i can have are 215/50 and rims no larger than 16" on the front and back.
is this true? are my rims illegal?
thanks
The vicroads standards state:
http://www.vicroads.vic.gov.au/Home/RulesS...rdsInformation/
http://www.vicroads.vic.gov.au/NR/rdonlyre...8340/0/VSI8.pdf
"The width of any replacement rim must not be:
more than 25mm greater than the widest wheel specified by the vehicle manufacturer for that model or vehicle series."
Sounds pretty open, but 8inch wide sounds fine, you could even go 9inch wide since a GTR had 8inch rims...(I think)
"The overall diameter of any replacement rim and tyre must not be:
more than 15mm greater than largest diameter tyre specified by the vehicle manufacturer for that model or vehicle series."
And same as above for 15mm less...
Track increase is, from http://www.toyo.com.au/TechInfoPDFs/Altern...Regulations.pdf
"WHEEL TRACK
The maximum allowable wheel track increase is:
* 25mm for a front axle or rear axles with independent suspension,
* 50mm for other rear axle types,
* Zero for front-wheel-drive vehicles with McPherson struts and negative scrub-radius
steering geometry or a diagonally split braking system.
got me an EPA letter. only had the car 2 weeks from the date the police 'observed' my car with a 'faulty or loud' exhaust system.
its a jasma system from the cat back, with cannon and mid oval muffle
com'on....
ah well, see how it goes.
  • 4 weeks later...
Jasma approved exhaust? What brand is it? Jasma means its approved for legal use in japan, but will probably still be too loud and will not get under 90db.
My jasma approved fujitsubo exhaust wouldnt have passed the EPA i got. Just got a custom rear muffler made up to quiet her down. Got home after the test and just chucked on my original muffler :down:
just got my first epa for exhaust noise yay.
got a question. the nearest place for me to get tested is about 30-35mins away now can any exhaust place check to see if it is legal before i go to one of these places for the real test? i have a 5zigen cat back its a proper muffler to not a cannon plus has another resonator in the system.
The exhaust place (Ace in Ringwood) I use will tell you if it won't pass a test before you fork out for a noise test. They're also an approved tester.
http://www.aceexhausts.com.au/acehome.html
If you have a muffler, and a resi - you'll fail. Resonators do NOTHING to quieten RB's down :P
You need a dual muffler system, BIG mufflers at that.
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
