can someone get me the mailing address of EPA, so I can send in my letter, or if it would be better to call them, the number to call them at. Now, I won't be able to read their reply, and I doubt they're willing to send the reply to my address in Singapore, so how do i know i have an extension?
Here you go.
Environmental Performance Unit
200 Victoria St, Carlton Vic
GPO Box 4395 Melbourne Vic 3001
Tel 03 9695 2675
Fax 03 9695 2520
vehicle.enforcement@epa.vic.gov.au
make sure to send it in as a registered letter. You wont hear back for a couple of weeks. Provide proof that you are overseas at this time etc
won't the singapore stamp be sufficient?
i could photocopy my passport though.
  • 4 weeks later...
Currently selling my car and need to provide a roadworthy will any of this get past
Cracked muffler
This according to racv inspection
Oil wetness evident rear of engine
Gearbox oil leak weapage evident
Centre bearing rubber saged
Windscreen glass scratched
Noisy wheels possibly wheel bearing
How much do u think this will cost to fix?
Or would it get passed the roadworthy?
Cracked muffler
Dunno how much but that won't pass
Cracked muffler
depends who does it, i'm not referring to a dodgy either but some look harder than others some of those things wont get picked up but some will for sure. I'd say RACV buyer checks are harsher than RWC checks.
cost will depend if you fix it, or you pay someone else to do it all.
Not necessarily. RWC loose their license if they miss something, which is very hard to get back. RACV will do the checks but wont have to fix it, so they just raise everything which may not be a problem.
It wont get passed the RWC.
I reckon you might be up for around $400 to $1000 including parts and labour.
A windscreen is about $250 to $500 including labour these days. Gearbox out is a pain so there's a bit of labor there.
Windscreen's are cheaper than $250, im sure of it.
I'll find out how much my HR31 was recently, and the GTR. I dont rememeber em being too much.
Either way, that list, workshop doing it $600 at least
Ok well just back from mechanics and he said his going to try keep it under 1k. His changing the windscreen also fixing exhaust which has cracked, also found a leak on lh shocker, pretty much the list was a page long :O ...also light on spoiler is out and he said there needs to bea break light at eye level, seems strange that as long as I have had it has never worked....
Looks like I'll be lucky to get out under a grand, which really sucks
Well it sucks yes, but these are the hidden costs/maintenance that people don't think exists.
ALL cars cost money to run and its not just petrol and general servicing. Plus they are 15yrs old. I'm not at all surprised that stuff is on the list. The RWC for the GTR i recently purchased was 4 figures as well without a worry.
  • 3 weeks later...
So I got screwed by the Po-Po, can't really blame em, I was in the wrong. Gotta take the car into Macleod EPA vehicle inspection station once I've taken out the safc, ebc and 3inch exhaust. Anyone know how much the Macleod test costs?
Also, this is the second time the car will have gone in for a full inspection, the first time being a year or two ago at the Hoppers Crossing inspection centre.
I told the EPA guy who checked over the car last night that I had only ever gone in for a noise check only, he told me that in addition to going to Macleod, I'd get a formal warning in the post from EPA. When they look at their records and see that this is the second time I will have gone in for a full emission test, do you reckon they would send me a fine instead of a warning?
I'm just a little nervous about it, given that I'm saving up for an overseas trip in July and I've heard the fine is about $600ish.
  • 3 weeks later...
Does anyone know when all the rule changes occured (years)? i.e. the rules changed in 1989, and there are different rules for pre-1949 cars. I've read already on this thread that 1983 is another year. What are the rest?
Also, what are the restrictions? What can you do to a 240Z that you can't do to a 300ZX (just an example)?
Edited by Turboterrorist
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
