  • Replies 75
Posted Images
0KM/H...
Haven't hit the track yet...
But in a months time I might get to around 60-80km/h on the track (Skid pan WOOT!)
And I'm thinking of doing drag day the day after, so hopefully then aronud 170-180km/h...
ON M5 IN SYDNEY EVERYNIGHT WITHOUT FAIL FROM KING GEORGES ROAD TO HUME HWY 320KPH+ IN MY GTR TO GO SEE MY GF.
MAY BE STUPID MAY BE WRONG BUT I DO IT. ALL THE TIME.
LOTS OF PEOPLE TO BACK UP MY WORD ASWELL.
Edited by GTRGTR
You sir, are a tool! :D
i got bout 190 in 4th @ about 5800rpm on a private road. stil had plenty left and another gear.. nothing on other ppl tho i kno..
What diff do you have in the car? That doesnt sound right???
My best is 227km/h at Phillip Island. That was read off the Pfc that read 114km/ at 110km/h. So its probablt only 220km/h. Sad thing that is coming onto the straight at 190km/h. So that long down hill straigh only nets me about an extra 30km/h. I need more power :D
I might have got the RPM wrong there... i think it may have been a bit higher then...lol but i was in 4th
original diff so i was wrong dammit
Yeh but i got to 11ty billion m/s on the m3 going to see my man friend at the northern polar regions of mars. I do it every day swear to god. Weevil will back me up. I lol'd so hard a 320km/h that is for girls. Maybe this should be moved to wasteland.
Edited by ScorpR32
yor so awesome and dont give skyline enthusiasts a bad name at all!
^^^ i love that
any way to somthing constructive does anyone notice anything strange when on a track doing 180km/h? ive found car feels good but it starts to sound like the doors are about to fall off. i know this may be the door seals but ive been in plenty of imports that whisle just doing 100km/h and for mine i need to be doing 180.
i also have a 260 or 280 cant think nismo speedo in my 32 but still have the speed cut in it. i find it gets to 190 to 200 before backing off. its also auto and has heaps of legs left in it as i find it will still drop back a gear if im doing 150 in over drive.
also when is that over speed chimer in the car ment to kick in??? i thought it was ment to be around 100km/h? but mind does nothing till 150.
oh and i forgot to mention if i hit power in my auto at 180 it gets completly 90degres to the road. lol
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
