Recently i did all the plastics for my mates 34,heres some pics for you guys that wanted to see what a black colour would look like.its called saturn black its also heat and chemical resistant. theres some befores and afters in there too.
  • 5 months later...
has anyone done this on a r34 with the popup screen? What extra steps are involved if anyone knows ???
Also does anyone know a good shadow silver/charcoal paint colour? I don't wanna do it up in black so as to leave a bit of contrast (like the original)
Oh and does anyone know if you can replace the led/light inside the radio/AC Unit ? my dash leds are blue and the radio/ac are green so I'd like to change these to blue as well when I take all of it out
Jack, any chance of taking a couple of piccies of your mates interior now with all of it back in place? Good work by the way, wish I had mates like you :P Cheers
Edited by Delta Force
Jack, any chance of taking a couple of piccies of your mates interior now with all of it back in place? Good work by the way, wish I had mates like you :banana: Cheers
In my first post I've got a recommended colour for the plastic, go to supercheap and check it out, it's a good match :)
So you sprayed them all white as an undercoat, and then used the saturn black as a 2nd coat??
What about those duplicolor brands.. are they any good? they have the pewter color that matches nissan sonic silver which the guy from autobarn showed me from the book.
Do you Guys spray clear coatings after applying the paint?
I used 3 coats of clear coat on the trim parts I painted. A bit overkill and when the sun was out the gauge cluster would reflect a bit onto the windshield
would probably need 2 coats max for the gauge cluster, put as many coats as you like on the rest :(
I posted these somewhere before but here's my effort:
I used powerplus paints too
Edited by Yo-Yo
hey guys, how do you take off the aircon surround??
hmm okay i had a look at it,
aircon is gonna be a tricky one to do with the red & blue temps around the dial which i want to keep.
ill do everything else tho.
see how i go
good to do over the xmas break :)
Edited by dori32
looks very nice .. I'm gonna do the same to mine but do the vents and aircon and perhaps the top lcd cover (I have that popup screen) in black. Then find some nice silver pedals and a silve bezel insert for the console and the car shouldn't look so 1998 anymore (maybe a bit more like 1999) :banana:
Speaking of which I'm going to go and rip out my (broken) lcd now ..wish me luck!
ok whatever you do don't use SEPTONE paint/primer .. this shit is just evil, I wasted 4-5 hours only to realize the paint itself is a POS. Will go looking for Powerplus paints tommorow.
i wanna do mine but the only thing that worries me is the AC controls. the blue and red thing around the knob did you guys just tape it up and spray painted the whole thing???
and can some one provide a step to step process and dismantling the ac unit???
the whole centre console (ac, stereo etc) slides out .. it's just 4 screws holding it in there. The blue/red on the AC is piss easy, just take them out as well as the clear plastic and spray the rest. Then glue them back in afterwards, it's no big deal trust me.
yeah it's all just clipped in ... the only thing you should be careful about is removing the vents - use a thin screwdriver from the left hand side and they'll pop out too. Make sure to protect the corners with masking tape to avoid accidental scratches when poping out vents and sliding out the console etc
To reveal the 4 screws holding it all in place, remve the gear shifter surround (pops out once you remove the screw behind the ashtray) and the vents - don't try removing any other fascias whilst the console is still in there. The vents will reveal the remaining 2 screws.
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
