Bubba, has it ever single pegged since shimmed? Also does it still chirp around tight corners?
Nope, no single pegging and it doesn't chirp around tight corners anymore. The only time I can feel it bind up slightly is full lock, reversing out of a parking space.
Even at its' worst (when it was nice and fresh), it was still nothing like trying to park the 32 with a button clutch and 2-way :P
Ive rounded off the righthand side nut in this picture. about to pour petrol over my car and throw a match on it..
Tried smashing on another socket but its so hard to hammer it in the position its in.
Soaked the crap out of it in wd40
Any help would be appreciated.
How do you round off a nut when your using the right size socket? are you sure its not the ratchet slipping? try using a breaker bar and see if it still slips.
Only other thing i can think of, assuming you havnt round it off too badly, buy an impact single hex socket, in the mean time just keep soaking it in WD40 every 30 minutes or so, by the time you get a socket tomorrow it may have made a difference.
Edited by W0rp3D
not sure, the other one came off relatively easy. its rounded quite badly by the looks of it. just got the oxy torch on it, if i have to i'll replace the bush in there.
i doubt theres a more difficult place to round off a nut haha. oh well, extra points!!
mines working well for what its intended for, worn in with in a week and is nice and locked.
now has anyone set the backlash before and do they have part numbers for the backlash shims on the crown wheel?
now my diff does get some hard use now and again and it's started to chirp the rear wheels while driving normaly, straight with good tread tyres etc would this have anything to do with using castrol manual vmx 80 or i figure its also that i have to get backlash set ( as there is some play more then before it was shimmed )?
thanks :pirate:
  • 4 weeks later...
I will be considering doing this as my car really does not like giving me two wheels anymore. Straight line I am ice skating everywhere and it is definitely one wheel spinning... I tried to spin the tires(not for show but just to test the diff) and it is definitely only using one wheel when its spinning.. I don't care for burnouts but if I could tighten up the straight line action, that would be great but from reading here it seems this has more effect when the car is sliding/turning/coming out of turns etc and straight line its still a one wheel... Nissan should have made this diff tighter..
  • 2 months later...
seems the appropriate thread to ask, anyone removed the pinion out of their diffs??
im in the process of removing mine, have removed the large nut (bloody tight) and splined flange off, the centres already out
tapped the pinion end with hammer lightly with the nut on it, but no movement
suggestions?
suggestions?
It's not a proper LSD, just a highly preloaded VLSD, so it basically won't lock up much harder as you accelerate and you are relying upon the preload to do all the locking for you.
  • 7 months later...
allright dudes,iv just finished with a mate his r33 lsd using 1.2 shims its allright but going more after the weekend,tryed getting 1.49s but nissan can only order them in from japland so i settled with 4- 0.8 and 4- 1.2 so im sure we'll get it good and tight soon,had a wee run there but not to happy but we'll give it a weekend first and c, ill keep yous posted
  • 3 months later...
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
