Well I finally dyno tuned the evo last night @ RE Customs - Mods are additional boost, APC Exhaust and Ralliart filter.
Final result - 229.1awkw - I'm VERY happy with how it turned out to say the least. Mixtures are nice and rich (11.5ish:1), and it pulls like a freight train through every gear.
I tuned it myself using a combination of ECUFlash, EVOScan and Dataloglab (fairly cheap tools)
Best part - I ran my car there when it was standard, and it made 147awkw - so it's picked up 82awkw over stock.
After finishing the dyno tuning, I ran 4 4th gear pulls back to back and they were all within 1-2kw of each other, with no signs of the engine starting to pull timing.
I've got to say - a BIG thanks to Ray from RE Customs for use of the dyno (and operating it) whilst I was tuning - he's a top bloke, and as everyone else has said, I'd definitely recommend him!
Cheers,
matt
https://www.sau.com.au/forums/topic/166261-team-cheater-evo-ftw/
Top work Matt!
I was sceptical at first - but so amazed at how quickly you could change things on my car. I think the case-of-beer and some dyno time needs to certainly slide in before 12th May...
No probs - I'm going to be down there next week tuning my brothers car too. Maybe do yours at the same time if you're not busy?
Top work Matt!
Fantastic work mate!
Looking forward to upping the boost a bit now on mine :P
It pulls very nicely through to 7K and exhaust smells richer after the remap too. Idle is fine and as is all the other bits. Good job Lowthy :P
Nice work Matt. Makes me feel underwhelmed by my 320rwkw@14psi in the GTR33.
Jokes aside though, I'm looking forward to doing the DIY thing on the GTR and the GTS25t with 26/30. Such a sense of satisfaction, now get rid of it and go Nissan..... you know it's the only way to credibility.
BTW Vic members, my new fridge has 200hp, more than most 20's ....... even more than GOLGO too I expect. :(
That's an awsome result, I have no idea what you tuned it with, sounds like software.... any hardware there? DIY rocks!
I haven't tuned a car for years, last time was on an unfamiliar dyno on a VL turbo with a Gas Research system that you can tune with a vice and a metal file!
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
