M35 averaged 9.69L/100km in the last week. Lowest was 8.00L/100km between Mildura and Wagga Wagga. That includes 3 days of city driving around Canberra so I'm pretty happy with that. Return trip was a bit thirstier due to head wind, more overtaking and.. urgency.
8L/100K is impressive. You running E10 or something?
on 98 i got 606 out of a tank,
it was a mix of city & highway,the mods i have are high flow turbo(stockish) high flow cat hdi inter-cooler and a k&n high flow panel air filter.ill be doing the same trip this weekend and ill try some 98 and see what i get this time around.
Screw you guys, I'm averaging 14.78L/100kms, according to the app on my phone. Best run was 12.37L/100, worst was 18.07L/00, but I think that included the drag day @ WSID.
Then again, I don't drive for economy.
+1 to this , I enjoy 2nd and 3rd gear too much.
I can understand C34 owners getting upset when M35 owners rub the C34 noses in our glorious 5 speed auto box, more leg room, less cabin noise, better weight distribution, newer technology, better handling, better interior, better ride, more room in the back, better stock power and better fuel economy....... :devil:
Most of what you said was true but I gotta say you can keep your "glorious" 5 speed auto gearbox. Its like this :- the VQ25DET is fantastic, but the laggy gearbox will keep you from really enjoying it.
I've owned both C34 and M35 - am back in a S2 C34 now, and my summary is as follows:
The ONE thing wrong with the M35 = drive-by-wire. I'm not sure if the drive-by-wire was the cause of the problem, but the gearbox was laggy as hell, and for me it really hurt the car.
Yes, the M35 is newer, and better in almost every way, except that in a stock for stock comparison, the C34 auto & throttle is WAY more responsive.
When I sold my M35 I stupidly bought a 2007 Ford wagon - what a heap of junk! After learning the hard way, I sold it after 3 weeks and returned to a stagea, but went for a C34 due to the lower price and lower running costs.
Both cars are great to own and drive - the C34 is more responsive and more "raw" (I think you feel more connected with the car), while the M35 is more comfortable and more luxurious (while being actually faster and handling better).
While on the topic of fuel economy, the difference between the two cars isn't that great:
My M35 got ~12L/100km city & 9.5L/100km highway
My C34 gets ~12.5L/100km city & 10.5L/100km highway
The M35 has different gear/diff ratios which helps a lot on the highway (the extra gear does make sense here).
Always get 400-450k's to a tank before the fuel light comes on in our S2 C34 with Neo RB25t. However, last tank we only managed 350k's before fuel light came on.... any ideas why? For the first time ever the Engine warning light came on too.
dead o2 sensor
or dying coilpacks
or boost leak
I'm at nearly 400ks for this current tank and it's getting damn close to fuel light time. I reckon I'll just nick 400 when it comes on. I would expect better for the driving I do (works out to be around 15l/100ks).
Mostly suburb driving. Still haven't figured out what my crappy miss is. Starting to lean towards coil packs. Might try gapping my plugs down and see if that helps a bit.
how do you test the o2 sensor?? i have been getting 350k's per tank for awhile now.
The best way to test them is is go here - http://www.skylinesaustralia.com/forums/topic/135194-ntk-nissan-lambda-sensors-o2-sensors/page__p__2513840__hl__sensor__fromsearch__1#entry2513840 - buy a new one and replace it.
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
