I'm at nearly 400ks for this current tank and it's getting damn close to fuel light time. I reckon I'll just nick 400 when it comes on. I would expect better for the driving I do (works out to be around 15l/100ks).
Mostly suburb driving. Still haven't figured out what my crappy miss is. Starting to lean towards coil packs. Might try gapping my plugs down and see if that helps a bit.
there is a procedure to get the stock ecu to flash it out
or buy a new one
check your pcv grommet, mine was cactus and made it idle a little off
or buy a new one
I've got a PFC.
Haven't checked the PCV yet.
Back from out little Cobram camping trip yesterday...
Filled up with 74.52L. Trip said I had covered 964kms.
12.9km/L or roughly 7.8L/100 :)
Downside was that there is a section of my current map that dumps fuel like no other (can see the economy drop 5-6km/L on the leaf almost instantly) and causes a "Bank 1 too rich" (0172) CEL. Just pull over and clear it. Doesn't pop up again unless I forget where it is (throttle pedal position at certain speeds).
Didn't show up at all yesterday :D
That's bloody good economy Cam!:thumbsup:
Has yours been on a dyno yet, or are you just running a "Guesstimate" tune atm?
Be very careful Cam... your economy is better than my car and I know I am running lean.
Yes. It was an a dyno for a tune, but had a clogged fuel filter (prob the one from factory as I'd never changed mine).
Massively lean above 4500rpm but below that the AFR's were "good", so it was only tuned below 4500rpm
Filter changed last week and my normal economy of 9.7km/L dropped to 9.3km/L (same driving) and was much more difficult to keep high.
Seems very lean Cam, want to borrow my spare wideband?
Yes, will need to work out a time to come over methinks.
So I hear :)
170k's to half tank. BP98 :(
Half a tank might not be half a tank. Run it to the fuel light and then see how much it takes to fill and calculate from there.
  • 3 weeks later...
I'm just managing to squeeze 200 ks out of 30 lts of premium just city driving , this seems like it could b better , only had the car for a short while ( 250 t rs four ) aero pack , really enjoying the ride but would like some better economy , can you make any adjustments on the trip comp to the leaness or do you advise a run on the dyno , it's due for a service in a couple of months what should they be doing to improve economy
You cant tune without some method of adjusting the timing and injector pulses, like an emanage or Fcon. Even then you will find on cruise there is little improvement in economy as the stock ecu does a very good job of it anyway. It has to, to pass the emissions test.
As far as making it all run as sweet as you can, change the o2 sensor in the exhaust, get your injectors cleaned and flow tested and run a good quality oil and all should be well. :cheers:
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
