  • Replies 100
hey listen andru, that's completely uncalled for.
if you arc up everytime you're told you're wrong, you're in for a torrid future mate.
ok so calling you a dickhead might not be the best thing, but you were wrong, simple as that.
don't get defensive, just learn from people who know.
threats made on a public forum, are exactly that, threats. legally, you can be held accountable.
if you were like that to any of the admins, I'm sure you'd be out.
all i'm saying is chill out - be smarter than that.
take it easy.
ahahhaha see wat i mean justin,
i dont think i can even find the very 1st thred i amde here about 2-3 years ago.
basicly still in high school i was 17 years old and wanted to know how much a R34 was. eveyrone on here laughed at me and told me to F off.
a year later posted up pics of my new ride, no one believed me.
all I want to know is if you were 17, 3 years ago, and you're 18 now then can you please direct me towards the fountain of youth you have.
also, "dose" is a colloquial term used to describe catching a variety of STDs....
On a serious note are stock bovs blocked because they only allow a certain amount of psi through?
no, so people can make 'cooler' noises.
even if the BOV was limited in bleeding off excess pressure (boost), it would still be better than nothing, rather than blocking if off entirely.
see how many GTRs retain their twin factory BOVs - they work well and work on MASSIVE power cars.
i would go so far as to get a spare pair in case one of mine breaks.
Sorry I meant Rb20/25's, Im not sure about gtrs, everything on them seem to handle high HP well.
Im sure I heard somewhere that the factory bov's on rb20 or 25 won't do much over 12 or 14psi?
Hes talking about the standard BOV, not turbo. My cars been on 14psi daily for over a year and a half and its never skipped a beat, altho my stock bov was blocked ages ago thats why I was wondering what is the limit of a stock bov.
Edited by Lukaz
wow this topic got a little heated.
on a happier/funny note. while watching those "dose" videos on you tube, i stumbled across this.. i found it funny. if your got 4 and a half minutes to watch it, it may put a smile on ya face.
truck dose. (little off the topic)
You assholes are as funny as hughsey with a pelican in his pants.
I remember the first Autosalon....... every clown blocking their BOV and revving to hear the sik tunes!
I have received much enjoyment from reading this thread and for that I thankyou all, even the dickheads that are obviously not learning anything at tertiary school.
FFS, ROFLAPIMP.
(rolling on floor laughing and peeing in my pants).
you guys are nuttier than an elephants poo.
(as long as the elephant eats as many peanuts as suggested in many TV shows)
:P
Mid_nite - that picture I showed up the top will get you an extremely loud VL TURBO dose, its exactly what all the muzzas get on there car.
yer i know, I'll try that when I relocate the AFM, atm i got a 90 Deg zinc pipe off the turbo with AFM at the end, sounds like a VL but the flutter is not as long as the VLs, so I guess running no AFM will help that going on for longer?
no its just the fact they use the word "dose" where the hell did that come from?!? flutter is fine by me used to have crazy flutter on the 180 when my pod protruded out of my guard hahahaha. but yeh if you want a "dose" pipe get either an exhaust shop to make it or do it yourself (just measure what bends you need, go to an exhaust shop, get the bends then weld them together.)
Another mate had this guy come up to him when he was welding a cage. and goes "hey bro what you making? a dose pipe?" some people dont even know that its the intake pipe and think its a mistical mod you add to your car to make it "dose" the guy i just mentioned wants him to make him a "dose" pipe so his Prelude can make the noise "all i want is for it to dose"
DOSE is from thomo (thomastown) and it comes orginall from the vl's but 33's seem to be the bigest culprits now. Getting customers the DOSE is big money now....
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
