  • Replies 233
Hey Guys.
R32 GTS-T People REJOICE! I've sourced the rubber inlet pipe which I needed to get your silicone ones made.
So, YES I am offering the R32 GTS-T pipes!
BASS OUT
Hey ppls,
My hunt for a replacement for the standard 'sucky closed under boost" inlet pipe has never really ended, even after I gave up on the super difficult steel version I spent a lot of time on.
I've seen some which cost people $450+, I've seen others that require modifications to the standard BOV return and PCV vent hardware or pipes.
So I recently came across a a direct replacement for the standard corrugated rubber pipe in Blue Silicone! They are Hong Kong Manufactured (but isn't everyting these days) and are quite reasonably priced.
As you can see in the below pics, the pipes are a DIRECT replacement for the stock pipes but don't feature the ugly corrugations that are no good for airflow and these shouldn't suck closed due to there stronger wrapped silicone construction.
No additional hardware is required, even the standard clamps can be reused I believe.
Freight rate will be calculated on a 3kg Post Satchel with Austpost and will cost $20.
Pricing is as follows.
Inlet pipe $ 135 each
Radiator pipes $ 110 per pair
So, who is interested in these cool new items?
R32 GTS-T
1 Haysey.............Black
2 lach 32.............Black
3 SNISMO............Black
4
5
6
7
8
9
10
R33 GTS-T
1 MANWHORE..........Black
2 SoFly...................Black
3 Govich.................Black
4 RSTME.................Black
5 jeffworld2.............
6 wolverine.............Black............................PAID
7 tuitahi..................Black
8 Zilch*..................Blue
9 (B1) Mr Fanny.......
10 dOOdz.................Black
11 johnnilicte............Black
12 russo1.................Black
13 Gtshortie..............Black
14 r33_nikolas...........
15 siddr20.................Black
16 Race__24.............Black
17 Basti....................Black
18 oosx....................Black
19 Taxi33..................Black
20 Darrinspencer.......Blue
21 Fry_33..................Black
22 Shano3000............Black
23 R33Driftr...............Black.......Black
24 frx026...................Black
25 beastien................Blue
26 FLYSLY..................Blue
27 WogsRus...............Blue........Blue
28
29
30
R34 GTT
1 Bass Junky..............Black.......Black
2 Wolverine................Black
3 Black_Widow R34.....Black
4 J34..........................Black
5 so_tred....................Black
6 Haines.....................Black
7 Darrinspencer..........Blue
8 Brycey.....................Black
9
10
BASS OUT
G`DAY bass IAM IN STAGEA S2 BLUE PLEASE will deposit fund thursday.chuckie
Hey bass i pmed you a few days ago but didnt get one back. I am extremly interested in geting one of these in Black for an R32 GTS-T. if you could update me that would be great , cheers Tim
Hi matie, i will be buing just the intake pipe not the rad hoses aswell.
When this group buy finishes will there be another one, i am just going through setelment of my house and money is coming and going avery week.
Thanks
Bass,is there much difference between the r32 intake pipe and the r33 intake pipe
as i want a black one for my r32 which has a rb25 turbo on it.
which pipe will i need?
i run stock airbox,afm & bov
cheers
hiya bass please put me down for a black intake pipe to suit a series 2 stagea.
will deposit coin into bank on friday and let you know details etc friday arvo.
(lets just hope this buy goes a bit smoother than last one eh?)
cheers oxford
RSTME
the R32 GTS-T Version will be for you then.
The location of the RB25 turbo in relation to the RB20 engine will be exactly the same.
The difference is more at the other end.
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
