  • Replies 233
Wolverine.... Um. yes whoops.
The vast majority of you should receive your parts either today, or tomorrow.
If you are outside of the Express Post regions, it might take another few days.
Sorry for the delays with this group buy, they were out of my control.
I did however run out of bags (cos of my stuff up with Wolverines) but I should be able to pick up some more bags sometime this week during lunch.
I think there is like one person who is going to have to wait another couple of days.
I hope you like em!
BASS OUT
Just got mine. Thanks. Will do trader rating once I fit it in hopefully this weekend. Speaking of which anyone installed theirs yet on a R34? Any problems/tips?
got mine today, certainly looks the goods will see how it fits when i am at work over the weekend.
cheers oxford
Hi Guys,
Okay, Melbourne people who haven't paid for freight and need to pick up their guides from me.....
You need to give me a bell and organise a time to grab them off me.
This weekend I'm pretty flat out after work painting my sons bedroom and Friday night I have a family dinner thing, and this Saturday we've got DECA, so it can be either Sunday, or early next week.
We could quite easily do a mini meet on Monday or Tuesday night if that's good for everyone?
The following people need to pick up their guides off me.
VSUTE
frx026
FLYSLY
(B1) Mr Fanny
Brycey
Let me know what's cool with you guys.
Cheers
Pete
Just got mine today, after I rang up and abused Australia Post for their Snail Mail Express Post service.....
Australia Post sucks sometimes - Not regarding the GB, but I'm waiting on an EMS package was sent from China last Thursday 16th, got to Melbourne Monday 20th at 12:43am and almost 4 days later, I still haven't seen it. Australia Post takes over the delivery of EMS stuff once it hits Oz. :P Express my a$$.
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
