  • Replies 539
260kw is pretty sweet, but i want to see more from this package :rofl:
i f*cken love the black plenum too - i'm assuming you bought it like that? the lack of piping is very nice, though i want to see you tidy that engine bay up a bit more :(:rant:
the package has more to come for sure ,the plenum was the normal greddy silver and i got a mate to paint it for me in 2pack.
She's gonna be one hell of a beast my car is going to undergo an engine transplant, where is your location and who's doing all the work on your car PM me please, Hame
pm sent .if you need any help just ask unlike some i like to share info :laugh:
nice engine bay. what you should of done was paint the plenum white also and continue the red lines onto it.
thanks. it sounds easy but its not. the engine would of had to be put together then air brushed then cleared while working around the mechanic and doing it all in three weeks with out pissing off the spray painter ,the air brush dude and the mechanic.originally there was going to be a samurai sword on the plenum but i ran out off time.i still might do it.
Edited by WARLORD
thanks i hope fellow modifiers don't copy and it stays original .
lol, nice covers mate. but i wouldn't go as far to say it's original... I've seen probably at least a dozen cars with the same thing. considering people have been modifying japanese peformance cars for the better part of 20 years there is not much you can do these days and be first...
here's just one.
here's just one.
geee thanks lol
Nice car WARLORD, I was having a good look through your engine bay the other week :D
thanks blitz iv tried lets see how long it lasts for. hahaha
2000 ++ km then a re-tune
Edited by WARLORD
  • 4 weeks later...
[email protected] psi low boost [email protected]
can any one recomend in sydney some where to go and get a power run done on the cheep .
thanks.
Wait for a SAU or club "dyno day"
Just saw this thread for the first time VERY impressive and a nice selection of mods.
I too have a HKS GTRS kit; but running Tomei Poncams, head porting, std plenum and std bottom end. My a/f ratios were kept at approx. 11.5:1, to keep the engine "safe". Running 18psi i made 268.2rwkw, but your response is WAY more impressive. Could be due to the plenum, cams, fmic (i was using a truck core), but most probably to the fresh rebuild.
The engine has since blown, while i was at a race track (cyl #3 dropped compression), and i have decided to build an rb2530, which means upgrading the turbo, again. I guess i will never know what the GTRS's true potential is, but yours demonstrates it clearly. Well done mate, an excellent build and it would feel awesome to drive.
Below is a comparison between our two graphs, you will be happy:
For my new engine i have bought a new GReddy plenum, XTR 100mm fmic, Garrett GT30R turbo 500hp (smallest recommended turbo), ATI balancer and a whole lot of other parts. Unfortunately it takes my mechanic a lot longer than 3 weeks to build an engine, but we'll get there.
All the best and enjoy :)
yeah pretty nice, fresh engines always feel so good, no when i did mine it was devine to drive, be interesting to see the potential of this setup, i'd like to know what sort of affect your cam selection of 256 in 264 ex would do for the package... im interested in these cams myself
All the best and enjoy :D
thanks and good luck with your car let us know how it goes.
  • 1 month later...
  • 8 months later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
