  • 2 months later...
Just to clarify once more.
I blew my turbo had shit on both ends out the exhaust and in the intercooler. Front blade is plastic, exhaust fins are ceramic. Both S1 and S2 R33s have ceramic/plastic turbos.
Why I have no ABS in my S2 late 1996 model? I was told they were offered as extras at the time...
Edited by Pauly33GTS-t
  • 1 month later...
Just a quick question guys...drivers airbag didnt come standard on 95 model R33's is that right? or can they be removed or something? the one im looking at buyin has no air bag obviously...has a sprts steering wheel on it?
S1 is metal S2 isnt
No not all 95's came with a airbag but remember that some owners in japan got the airbag option fitted to a car as i have seen a 93 R33 GTST with duel airbags
  • 4 months later...
OK, my brother has a series 2... the side GT badge, is white and blue... anyone elses this colour???
i now realise these mean NA,, but being his is factory turbo, id say previous owner just changed to go with the white and blue flake paint or something
Edited by Silver_R34_GT-T
  • 3 weeks later...
I stumbled upon another difference between mine and a series 1. The fuel rail on an S1 is held in with 5 bolts while mine only has 3, the series 1 needs all of them to hold it in place and my manifold had the holes pretaped.
  • 5 weeks later...
Not sure if any mentioned that the s1 has the battery in the boot? and the s2 has the battery in the engine bay...
Supposidly I have a series 1.5 but i can't tell. Looks like a s1 in and out. although the velour seats are completely diffferent from the old looking s1 seats and also the s2 seats.....
nope sorry mate s2 has battery in the boot as s1 did....
if it is a series 1.5 you will not have an ignitor pack at the back of your cam cover - its a small box say 10cm square. the coils handle the different voltage.
IIRC this is in fact a diffreence between sedans and coupes not the two different series. like duncan said, all r33 coupes have the battery in the boot
is it too late to post..
im not 100% on these, so please correct them if they are wrong..
but i think
- the trim has a different pattern? and changes to a more cloth material ( so i am told )
and also,
- the cluster has different positions on some of the warning lights.
**sory if its a repost and i happened to miss it.
i have a 04/03 (complience date) r33, series 1 externally, but it has a series 2 engine... possibly first 1.5? or has my engine been swapped haha? (n i can tell my engine series 2 cos has no ignitor box, 2 plug TB, and different AFM then my mates series1) but how do u tell if engine been changed? cos the engine number aint on the factory tag :S
  • 4 weeks later...
  • 3 months later...
Q; What is the difference between a series 1 and series 2 R33 Gtst?
A; There are several differences...
* The front end of the series 2 is sharper, slimmer headlights, different front bar (indicators and fog lights are round and located at the bottom of the bar). The bonnet has much sharper ridges.
* The "skyline" panel at the rear of the car is body coloured on the series 2.
* The interior of the series 2 has been updated including different trim, a passenger airbag and the dash facia has been updated.
* Mechanical differences include an updated ECU and a ceramic turbo.
* The series 1 was in production from late '93 through to late '95. The series 2 ran from early '96 through to early/mid '98.
ok.. this means i cant change my s1 bumper in to a 33 gtr.... can i? :laugh:
  • 4 weeks later...
theres a list of what was different again on the 98 series 3 models in high porformance imports think it was like the second last issue! more factory options avalible agian on these ,haha
Not sure if this has been metioned but, the series 1 has 5 seat capacity where as 1.5 and up has been lowered to 4. I.E no middle seat in the series 1.5 and greater.
yep. its got the middle one. And on the purple/pink compliance sticker it says 5. Thats my friends one. His one is 1993.
Mine which is 1995, has no middle seat belt and on the purple/pink compliance sticker it says 4.
hey, can someone tell me if the series 2 side skirts are the same as series1?, ive cracked my skirts and need to buy some more, but the series 1 skirts look a little different... are the series 2 skirts the same as gtr skirts?, thanx if some one could help me out :down:
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
