Mods are cooler and exhaust, its in an R32 and everything on the motor is stock... except for the RB20 remapped ecu thats running it.
Dyno run with the 33 ecu was a hell of a lot less. As we all know the stocker hits R&R with raised boost. Now ive got loads of midrange torque and driveability is sweet as.
For the bucks.. its a sweet upgrade for those 33 owners looking for some more poke... chuck those 33 ecu's in the bin.
  • Replies 40
Those are some nifty results simon. what are you doing to control VCT? I can see it it coming on at 100kmph so in 4th with your diff ratio i am guessing that is around 3700rpm?
really keen on this as i may be going a 25 shortly and would like to retain my ecu and harness
forget about retaining the loom, its a fair wack of work just to do it. Just run the 25 loom with a 20 ecu and you'll be laughing.
No VCT here either, its off and not really needed. Cant say ive noticed any lack of low down.
My rb20 with slide highflow was making 225 rwkw on 16-17 psi with stock injector / afm /remap then i swapped in the 25 which now makes 10 kws less, with stock turbo and had an insane amond of midrange torque compared to the rb20..
Overall im pretty happy with it.
unknown Telly gave it to me when he worked out it wouldnt fit in his 25de
as they were 33 cams one was a 256 hks thing the others a tomei supposedly
could find any info on it but it did have b673465 or something like that on it so sounds like tomei
he's now gone 26 now anyway
Yeah it gets drifted, ive kept it under 1 bar which is to keep it safe, Should be safe at just under 13psi i would say.
I just say it because i've seen a couple turbos @ 12psi let go on track days.
And others who had killed them @ drag days (12-13psi also), and the drag ones are even less time/heat.
Some last some dont, guess its luck of the draw on that one
same with soarer's i got a friend been thrashin his poor ceramic turbos @ 14-15psi for nearly 2 years no drama.... but his brothers didnt last a fortnight... lady luck is a bitch
haha turbo tune dyno..... should make 190 everywhere else :D Nice curve though.
Prob been a while since youve been there but they now have the most accurate dyno in Adelaide. If i wanted a high reading i'd go to tilbrooks and wow people with 240 rwkw's from the same set up :)
Prob been a while since youve been there but they now have the most accurate dyno in Adelaide. If i wanted a high reading i'd go to tilbrooks and wow people with 240 rwkw's from the same set up :D
+1 recently had mine dynod there when jeff remapped it and before the remap it pulled a little bit less to what it did at boostworx with the same mods. as said they have a very accurate dyno.
that result is very impressive, if i ever get the $$ ill seriously look at going RB25.
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
