car should be at QR inthe morning tomorrow!! for a bit of a shakedown, testing dry sump and breather setup, cooling system etc.
Awesome, i'll be out for sprints in the arvo so i'll make sure i get there nice and early to see your runs :blink:
Giant, sorry I could not come to QR early enough to see your car. How did you go? Is there any chance that you could post some pics of the lexan windows? I think I need give my skyline the Jenny Craig diet :)
hey guys
for an update!
went out saturday morning to do a test. did about 15 laps maybe 18? ( in 3 sets)
intial test! result excellent!!!
dry sump test - perfect
cooling system, oil and coolant- perfect
doors and windows didnt flap around
cage result - really feel the chassis stiffness
testing at about 85 percent on re55 hards, mark did a 1.17:5 on the national which beats our previous best of 1.17:9
very promising on soft semi's at 100percent should put us into the 1.16 bracket wven there werent other mods.
next to test is
ohlins coilovers (due this week)
4 inch side pipe :laugh: (already made)
different injectors (ready to go)
soft compound rubber (due now)
will keep you posted and some more pics soon.
cheers russ
p.s we did have an oil leak (helps to put the dipstick in or plug the tube/hole!!)
i was there and saw the 32 go round...it is damn fast and its not even finished yet. The japs wont know what hit them.
While russ and mark had a good run, we blew a turbo the same morning :) Seems a perishing rubber line that supplies oil somewhere had bits building up in the turbo oil feed, blocked the hole and ceased the turbo.
P.S I love the doors russ, so light. Im telling ya mate, full slicks. Try a few runs on a set, you will wet yourself with the amount of traction you will get over the hard semis.
Latest pics of my rally car from this weekend...
7 fence posts at 130km/h
Damage report:
Bent right rear suspension, looks like just the lower rear suspension arm
The scratch (and small dent) on the rear guard
Missing fuel filler cap (somewhere in a padock)
Missing rear window (also spread across the paddock)
Squashed fuel tank - surprised it's not leaking actually
Bent wheel
Broken headlight
7 fence posts (One thrown 15m into the paddock where the glass and petrol cap are)
Bet you didn't lift off though?
Kept the foot in it the whole way, until it started heading for the bank, then I gave up and applied the brakes. Just needed more steering lock! Strong old things tho, once untangled I drove it out of the stage.
Damage report:
Bent wheel
Broken headlight
hehe!!
thats the shit right there!!
130 clicks hitting fence posts and the foot still buried!
love ya work!!
cheers russ
Hey screamin' - I found out last week the Dutton Rally is having a round in N.Z. next year. We are currently planning on getting over there for it. Hopefully we can see a few local based Skylines for the event as well.
BTW Russ - no round in QLD next year. So you guys will have to come to Vic (or N.Z.!)
ahh damn it!! means i dont get a cheaper round.
might have to come to vic to play!! :yucky:
They are stepping up the Dutton events next year Russ. Some of the stuff should be tops. :yucky:
Also - I've pretty much convinced Mossy to bring back the free entry for reigning champs so you should at least get free entry to NSW next year. :)
Good man!
Hey sounds good. Dutton is a tarmac rally similar to a Targa isn't it? We've only got a handfull of guys running Skylines in that spec here. Most guys with money run the GT3's.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
