Testarossa in Hoppers today
There was 3 of them in Healsville the other week. The funny thing was you could spot the owners as they were out the front of a cafe wearing their ferrari shirts looking like twats. Why do so many Ferrari owners feel the need to do that?
I felt embarresed for them - especially since I drove past in this wearing a pair of baggy shorts and a t-shirt drinking a macca's coffee :blink:
I felt embarresed for them - especially since I drove past in this wearing a pair of baggy shorts and a t-shirt drinking a macca's coffee :blush:
If I owned a Ferrari, I wouldn't drive anywhere without my full Ferrari race suit, including red Puma Ferrari boots.
I bet they owned their Ferraris though, hero.
must be the same mobsters from the 'mob cafe' on bourke near exhibition.. no standing zones are apparently a great place to park your ferrari.. tho I guess $100 is cheaper than a banged up ferrari door in a $10 Carpark
Saw 3 Murcielagos (Yellow, Black, and Orange), 1 F430 Spyder, 1 F360 Challenge Stradale (Red with white stripes), 1 F430 Scuderia and some Maserati parked outside Brunetti's in Carlton tonight.
My god the Scud is sexual close up!
