howie are you watching the thread while thinking about buying a V35.... thats why i am always lurking
Frank.. TOP effort.
haha.. maybe subconciously i'm being steered towards a V35 :closedeyes: Would love a 350 though.
Thanks.
Have a look a t the newest issue of HOT4's, you will get dep understanding of V35, from WA's C-WEST 350GT
Yes my car is a good example :kiss:
But Correction, its C-Red - not C-West haha :D
JK
Hey Frank,
Would you consider doing another car? Mine is the 05, non BOSE but should be similar. I'm in Syd as well.
PM me if you like on how long it will take and your price.
I can take everything apart and help you as well, but am pretty hopeless with the rest of it.
Cheers
Bobby
Hi Bobby:
I am free this weekend. if you need me to help you with the A/V, please send me a PM, we can make a time.
Cheer
Frank
hi
any suggestions for those of us that already have a reversing camera (and my wife will kill me if i disable it cos she uses it everytime:) )
ok - have done one with a camera. fairly straight forward . camera still functions and DVD (source) works when not in reverse. cannot remember if audio switches out with camera on.
someone remap the FKN virtual buttons on these things! both of us had problems finding the AUX in on the screen.
pics:
DVD unit screen.
DVD playing- DVD is encoded in PAL. hence colour issue.
closeup of AUX in plugs
distant shot of aux in plugs
OE reverse camera
TV box - clarion box in corner is the camera switch box - for those without cameras I believe I can still make this work so you gain a reverse camera.
car in reverse looking up our horrible driveway..
there ya go- it does work.
(ta WAZ!)
man that's one sexy car!
it works great - when the aux input is playing, and you throw it in reverse, the audio doesn't cut but the video does. works well.
but i just realised that i don't have the ability to watch it whilst in drive, only when i'm at a stop.
does anyone have one of those boxes that cuts out the factory sensor for the brake so you can watch the screen while driving?
cheers chris. ive had a read of g35driver.com and it might be as simple as unplugging and grounding one wire that goes to the foot-brake, but i'm not 100% sure. i will also have a look this afternoon.. but i don't want to screw up some other electrics by removing a wire..
if its only the park brake then its no biggie, but if it also monitors the speed sensor then it might be an issue cutting that..
Edited by WazR32GTSt
  • 4 weeks later...
Thanks Frank for this, but do you have the photo that go along with the original post, they are not coming up....
For your reference I have found someone elses photos of a DVD System mod here:
http://photofile.ru/users/yura7264/
Using a "Mystery" DVD player...
Photos are working again now.... slowly but they do show up....
How is the video in Activated?
Edited by GTS4nMore
video will show up under VTR. select TV then VTR input. from there it will work if you have done every thing correctly.
it will not work witht eh IGN on UNLESS the handbrake is on and the car is stopped. driving the car shuts the video off at 5kmh.
I finally rigged mine up today and my video only stays on the screen for maybe 5 seconds and then it dissappears and some jap writing comes up. This was with the IGN on or car running, in park and handbrake on. As soon as I took the hb off the video dropped and audio continued, but the damn video kept dissappearing after a short timeout. Is this a user setting somehow? I noticed an option button in the VTR screen but it didnt make a difference. I have attached some pics of what Ive done.
PS for my cabling i used the wires from a 4 pin floppy drive power connector and some insulation tape - perfect :P Finding a suitable plug was too hard.
Image 1 - Video playing
Image 2 - Warning Message
Image 3 - VTR toggle option? What does this do?
Image 4 - Another warning
Image 5 - My wiring Job
Cheers
JK
Hi Jaik, its the display option. Press the 1st button on the 2nd row to go into the Display menu. Scroll down to the second option (should be 3 options available) then press enter to disable it.
Cheers
Cheers
JK
  • 3 weeks later...
I have set up my Stagea ARX with this RCA input and I have found that I can play the movies whilst driving. On my car it seems related to the setting of the GPS.
By playing with the GPS menu (right hand top button) I have found that I can have the GPS active or static. What I mean is that when the GPS is active it tracks me across the japanese map (although this is obviously wrong). I have found that I can make the GPS static, it does not track me accross the map but does show the direction I am heading. When it is in this mode the movies will play all the time.
When the GPS is active, the movies will only play with the hand brake on.
Very strange but great result.
Andy
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
