  • 2 months later...
OK i want to know if we change it back to Japanese?
I liked it better when the leaf worked the other way and old fuel consumtion calculation.
Yes you can. I will send you a japanese dvd rom for your one. Ive got a dvd rom that works fine just couldnt change it to english if you want to swap.
  • 1 month later...
  • 3 weeks later...
Just wondering, if it's not too late in the development cycle, can the fuel screen for the Series 2 be left as km/L?
OR if it is to be changed to L/100, can it be that the leaf goes from bad (bottom - red) to good (top - green) economy?
I guess I just relate a green leaf to good fuel economy. A bit OCD I know, but I use that economy screen All. The. Time. :)
  • 2 months later...
ive been searching this site for an hour and cant find the answer to my question
how do i get the secret diagnostic page to come up on the navi screen? i thought it was as simple as holding a button down as you turned the ignition on....
and can the answer to this please be put in the "read this first" sticky thanks
How long is "a while" estimated to be Brad? A year? Six months?
Also, since it is going to be a while, any chance (broken record time) that he can leave the economy screen as km/L?
I never get an answer Fedor just says he is busy with it. If Andy reads this he can ask Fedor about the economy screen.
thanks brad
any chance i can buy a navi disc off you?
I just have to get more dvds so I can copy it or you can bring your memory stick over and I can give it to you and you copy it onto disk yourself
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
    • Probably. I take it that they are also mentioned to be for R34 Skyline? For example.... RDA has that part as RDA7957. I have the dimpled and slotted version of that on my car https://www.ebay.com.au/itm/285518478694?srsltid=AfmBOopKxMuAFpsxZJdB1cam4D5RAj1f9yJyOttPZLAwXVNCOiwlhrIy This is DBA's top one piece equivalent https://www.ebay.com.au/itm/364246686631?srsltid=AfmBOorbb0XHQgqTvZLgQPhg70nqJtGvdojKnugum3O2LFSr2h-obp8D
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
