Deads are coming along again after a deload, only warm up weight for some but on my last 2 sets today I managed 5 x 150kg then 3 X 160kg, I should have only gone to 155kg and will drop my last set to 155kg next time.
I did manage a good 270kg from the top of the knee to lock out on my last set of 5 x 1 of them though, started at 250kg and went up by 5, I did make some noise though.
I am going to rotate between 3 x 8 deficit and 5 x 1 knee height to try and keep it slowly going up.
Sorted out all those injuries that prevent you from progressing yet Dan?
Is this supposed to be a thinly veiled jab somehow? Despite me having already said I wouldn't be lecturing anyone based on having injured myself with poor form/mechanics? If so, lol
100kg x 7 on bench, I think that's a pb for me!
Nice job dude. I'm slowly bringing up that 3rd incline set, started out at 54kg and the bar was very hard to control, now got about 75 on it and managing 10 reps (just) after doing 10 then 8 at of flat something just over 100, think it's like 102.5 or so.
Thinking I might drop the second flat bench set and swap in another incline set as I don't want too big man titties (I have cut eating also to assist until I can do some decent cardio again).
Edited by ActionDan
Mine are big enough now. I don't want them to be any bigger to make it easier when my metabolism slows more and I find it harder to change weight as easy.
My thinking is that as I get older I'll slowly lean off a bit over time to avoid sag if possible lol
Hahah, that's my thinking too, but I more so mean I'll step down in weights and move more into cardio as I get older. For that leaner less bulky look and hopefully that will help keep me tight like a tiger.
What's a better game plan then, legit question.
My theory is if the muscle is a little smaller through lighter weights higher reps and my body fat is lower through cardio and diet I should be OK.
I know muscle itself doesn't sag but the connective tissues do. Less weight on those would help.
Less fat is always going to help.
All old people sag - fact. No training will avoid that. Even skinny low fat triathlete oldies sag. You either get lucky or you don't.
Look at Stallone...as roided up as he is, he's in top nick for a man in his 60s...very defined...but you can see the age; you can see the sag. Nothing can be done. Deal wit it.
Keep the fat off and that's the best you can do.
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
