Did my 1RMs tonight - 230kg squat, 200kg deadlift, 120kg bench, 70kg press. Stoked about it - I hit all the goals I was after, and squatted more than I thought I could. 8 or so months of PTC beginner routine and eating LOTS of protein.
Now for my 5/3/1 to begin!
Paradoxically the only thing to cure my calf doms was squatting.
Edited by bozodos
I always go below paralell Birds, I try not to have hamstring touch calf though. Still at 120kg or so unfortunately - diet started to get a bit out of hand again lately. Would have liked to got 240kg squat for double bodyweight, but I didn't want to fail it.
Can't really remember my starting numbers, they were pretty damn low though - when I started the PTC routine I was benching around 40kg, squatting 100 or so, and deadlifting 80. I had to do dips with ~90kg assistance, which I can now do bodyweight.
I've started doing stair / hill runs and sprints to get some conditioning in too.
Sensational man, really happy for you, so jealous of the Squat and DL =D
Happy because you've worked hard for it and happy because your attitude has been excellent since the beginning, no bullshit, no ego, just getting in there and getting it done.
*BroHug*
  • Like 1
Good work Boz. Only real powerlifters squat more than they deadlift!
Don't need to worry about knee wraps but a belt for squats is really handy, especially once it gets heavy. Just helps you keep tight and makes the whole thing a nicer movement.
It doesn't really protect your back and only maybe gets you a handful of kilos but it's definitely worth having.
Thanks Nick. I'll look into a belt - my Chuck Taylors are here so at least I'll have some reasonable footwear. I've had a strong squat and legs since I started, lucky I guess.
Been agonising over 5/3/1 assistance templates, I decided on Simplest Strength due to it having a squat and deadlift variant more than once a week, and not eating enough to give BBB a hard go
5 sets of 5, there's a heap of different programs, Markos always used to reccomend it more for lifters beyond the beginner stage, and I'd agree with that.
Common examples of programs are: Stronglifts, LP Greyskull, Madcow, Bill Starr's 5x5.
Cheers boz, I had a quick look online but thought id ask my fellow gym sauers. I had a chat with a 50 year old at the gym today. This bloke is bigger than most blokes at the gym. He said for me to shake up the routine ( 5x5, pyramid etc ) he swears by the pyramid program.
http://blackironbeast.com has a good calculator for 5/3/1.
I have started the boring but big program 4 day, very similar to the program I was doing but all the % and sets are done for you.
I will roll with this for the full cycle (about 9 months worth) from now and see how it goes, 2 days in so far.
I like it as it seems its a "get strong for dummies" type of thing, which suits me down to a tee.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
