in reference to the Blood Type Diet (and author)
"A search of PubMed under the author's name does not yield any peer-reviewed articles with data to support his claims. For example, his claim that elderberry can be used as a remedy for the common flu lacks scientific evidence and may be misleading."
"D'Adamo claims many ABO specific lectins exist in foods.[1]:23 This claim is unsubstantiated by established biochemical research, which has found no differences in the reactions of lectins with human ABO types. Research shows that lectins specific to a particular ABO type are generally not found in foods (with several rare exceptions, e.g., the Lima bean) and that lectins with ABO specificity are more frequently found in non-food plants or animals."
also http://ajcn.nutrition.org/content/98/1/99
lol @ Tolga
What Gym/Exercising forums do you guys frequent. I want to talk to some other people who have been through the same back issue as me.
My planking is getting stronger but I'm seeing no discernible reduction in pain in my back.
ausbb.com
there is also aussiegymjunkies.com but bulk of the people on AUSBB are also there.
same same.
I don't think that proraw forum is for you.
I don't post on there Tolga - I joined it to see if Markos had any more wisdom to share, but it's mainly relating to GPC stuff that is of no interest to me.
I sometimes read the Starting Strength forum, but threads tend to derail after 2 or 3 pages
Edited by bozodos
I used to read starting strength, rippetoe can get a bit aggro on there hey!
had another session of crossfit last night.
it is amazing how unfit i am these days. Gone from being able to compete for 3-4 rounds in mma, spar for 12 rounds in boxing
to unable to do 40+ burpees in a single sitting
I hear ya, since cutting back on the gym a little, 35-40min sessions, and not doing any walking or running at the moment I've gained a couple of kgs even thought I've cut back on my food (not enough obviously)
Dem tight pants.
I meant it's not a forum for Dan asking about his injury.
ah yeah fair enough.
I do like that Rip posts on his own forum frequently and yeah I like him and Jim Wendler's No BS, straight talking approach (which was why I also liked the PTC Newsletters and Markos' very dry humour). I still haven't read Starting Strength in its entirety - next up is the 5/3/1 book as I'm intending to start in the next week or so.
I did have question relating to Rip's methods (for the more experienced here) - Is it ok to keep the back neutral and thrust with the upper legs for OHP like Rip teaches, or is that defeating the purpose of the press (legs shoulder width apart, pressing from the chest, not a push press)? It would certainly make it easier to get it out of the bottom.
There strangely enough doesn't seem to be much of an online presence for health and fitness forums in Australia (unless I'm missing something). There is Bodybuilding.com, but their forums are full of broscience phds, blind devotion to IIFYM, supplement company shills (and rajab forbid you ever say anything negative about any supplement ever) and tools. I do like select content there though, like Alan Aragon's writeups.
Edited by bozodos
knees don't bend in the method I am thinking of. hip position change? The starting point (bottom section) of the movement can be trained for sticking point but, mostly that's supporting muscle strength.
yeah hip position change. I used it today, worked well, but my form is quite shit trying to keep the glutes squeezed while doing it.
saw the regular curlbros doing deadlifts for once today, 170kg with completely rounded back. I really wanted to tell them that they were cruising towards snap city, but I thought that these two jersey shore wannabes would likely tell the fat guy who squats 3 times a week to f**k off and mind his own business.
  • Like 1
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
    • Gee she looks a bit rear heavy in that first pic! Sounds like a great project with the kids, but as I guess you know R series stuff is getting hard to find and pre that is pretty much impossible these days
