  • Replies 144
will this stop-over in Melb before the trip to tassie? via the ferry??
if so, Final Inspection for a final detail before Targa, must be done!!! A few layers of Royale will reduce drag like nothing else :P
so this means its the "donut" king....
lol it could almost pass for a sydneysider's daily driver... its pink... and it has bold claims all over it that it does hektik circle work.
nice work with the car. look forward to seeing it run.
have you guys sorted out the speed restrictions?
pink is the new thing these days.....I've seen some fully hektik mofos drivig around in pink charades. So spraying it in pink will give it instead street cred these days.
Orange, lime green, Magenta, Harlequin etc etc will also get you chicks.
on a more serious note, I guess when you think about it, pink on a car like this probably attracts more attention than the same car in red.
read back you monkey! mines VX rom.... :)
The car looks certainly AWESOME - props to Donut king !!! I will be making the Pilgrimage down to tassie to watch the beast in Action for Targa this year!!
Just a question - who in NSW is looking after/preparing the car?
I ask only Cos I thought the donut king cars were prepped in Melbourne - an old customer of mine, Monaro Performance Center, looked after and built a few Donut King cars, like there monaros, SSs and S15 200sx's!
Edited by Starionturbo
Yeh greg still looks after the monaro's and was looking after the S15 as of last year, Just Jap take care of the Real stuff haha
Edited by PHaT MR30
is there a Donut King corner on the circuit?
Should organise a group of SAUers with pink Donut King director chairs, all eating donuts out of their pink bags waving em around as the car goes past. (SAU shirts of course)
That's sure to get you on TV ! :D
Plus it would look hella funny :yes:
That's sure to get you on TV ! :)
Plus it would look hella funny :cool:
Haha! would be a hit at the Georgetown Prologue on the hairpin
but trust me, being in a car with the DK livery you soon get tired of people asking "wheres my donuts?" and its usually a fat shaz that dones't need em
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
