  • Replies 118
its obviously been done for a reason. before you all jump on your bandwagons, there is another side to this story obviously as its harder to do what was done than just replace with the existing sump plug. as for fark ups...I'd like to see any one here who hasnt farked something up before.
That's just not good enough, if it was done for a reason why wasn't the owner made a aware of it???
If there was something wrong with the sump plug and they couldn't get it back on they shouldn't have given the car back until it was correctly repaired/replaced.
Yeah your right we all make mistakes but this my friend is not a mistake, it's pure stupidity and not professional.
the point was shit happens and it doesnt necessarily mean the people at that workshop are no good and as such we shouldnt be bagging them considering we have no idea what really happened. Its fruitless debating potentioal scenarios to a situtaion you nor I have not been involved with. That being said I have never seen anything like that before and if that hapened to me i would be quite pissed to say the least.
But at least we know what to do when we loose a sump plug LOL
How are your NGK shares doing currently mate............... :laugh:
You said you went in there for idle issues, have these been fixed? Check your spark plugs, maybe there you will find your sump plug.
Hey if its idling fine now maybe the old 'swap the sump plug with the spark plug on cylinder 2' trick fixed it up.
:laugh:
yea shit happens, but you wouldnt want it to when your spending hard earned money
i reckon, they were putting it back together and doing a test of something, and couldnt find the actual sump plug, jsut for the time beig shoved that in.. then forgot about it
Sorry but theres just no excuse for that.Worse case scenario if he stripped the thread..at least let the customer know about it.or lost the sump plug..order a replacement...thats just seriously botched up...IF you make a mistake the first time then fix it and get it right the 2nd time,....no excuse for this
Bill for mechanical repair.
.5 hours labour to fix PFC Idle problem @ $90 p/h
5 litres Motul oil $100
7 new spark plugs $120
hang on a moment. 7 spark plugs??? where does the 7th one go? ahh I see.
My only fear is if in fact they did just forget to replace the spark plug with a sump plug then I hope they didn't forget to put oil in it too... I would be checking things over pretty thoroughly before doing anything else.
thats not a fark up, thats pure 100% dodgy and lazy. if they threaded the plug pulling it out ot something along those lines that is more definatly not the way to fix a fark up as far as im concerned. thats a horrable attempt at trying to cover up their stuff up.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
