  • Replies 118
its obviously been done for a reason. before you all jump on your bandwagons, there is another side to this story obviously as its harder to do what was done than just replace with the existing sump plug. as for fark ups...I'd like to see any one here who hasnt farked something up before.
That's just not good enough, if it was done for a reason why wasn't the owner made a aware of it???
If there was something wrong with the sump plug and they couldn't get it back on they shouldn't have given the car back until it was correctly repaired/replaced.
Yeah your right we all make mistakes but this my friend is not a mistake, it's pure stupidity and not professional.
the point was shit happens and it doesnt necessarily mean the people at that workshop are no good and as such we shouldnt be bagging them considering we have no idea what really happened. Its fruitless debating potentioal scenarios to a situtaion you nor I have not been involved with. That being said I have never seen anything like that before and if that hapened to me i would be quite pissed to say the least.
But at least we know what to do when we loose a sump plug LOL
How are your NGK shares doing currently mate............... :laugh:
You said you went in there for idle issues, have these been fixed? Check your spark plugs, maybe there you will find your sump plug.
Hey if its idling fine now maybe the old 'swap the sump plug with the spark plug on cylinder 2' trick fixed it up.
:laugh:
yea shit happens, but you wouldnt want it to when your spending hard earned money
i reckon, they were putting it back together and doing a test of something, and couldnt find the actual sump plug, jsut for the time beig shoved that in.. then forgot about it
Sorry but theres just no excuse for that.Worse case scenario if he stripped the thread..at least let the customer know about it.or lost the sump plug..order a replacement...thats just seriously botched up...IF you make a mistake the first time then fix it and get it right the 2nd time,....no excuse for this
Bill for mechanical repair.
.5 hours labour to fix PFC Idle problem @ $90 p/h
5 litres Motul oil $100
7 new spark plugs $120
hang on a moment. 7 spark plugs??? where does the 7th one go? ahh I see.
My only fear is if in fact they did just forget to replace the spark plug with a sump plug then I hope they didn't forget to put oil in it too... I would be checking things over pretty thoroughly before doing anything else.
thats not a fark up, thats pure 100% dodgy and lazy. if they threaded the plug pulling it out ot something along those lines that is more definatly not the way to fix a fark up as far as im concerned. thats a horrable attempt at trying to cover up their stuff up.
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
