  • Replies 241
you can have your 2.9l but who really needs power under 4000rpm in a gtr
after that us 2.6l are all over you like a fat kid on a cupcake :D lag is fun and is fixed by a clutch kick haha
You obviously missed the 9000rpm rev limit bit. Anything you can do with 2.6litres, you can do better with 2.9 :ermm:
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/4/#findComment-3658125
i'd like more info on where i can get one of these cranks that'll handle those sorta revs..
i think you will find its probably an off the shelf jap full counter jobbie as Lithium suggested.
Id really like to see that torque graph with a more "realistic" scale. As it will show what Ben has achieved in a better light.
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/4/#findComment-3658242
was also thinking that.. but who makes one which works out to be 2.9litre?
time to start planning wat i wanna do to new gtr :ermm:
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/4/#findComment-3658323
Apexi made an RB26 2.9L kit but my money is on the fact that it still runs a std Nissan crank, most likely the RB30 crank and block. But like anything, its no one ingredient that gets you these sorts of results. Its probably a combination of displacement, turbo selection, tuning, cam size and engine building and custom tweakineg from hours of R&D....all topped off with a tune that allows for what has been screwed into the motor.
Having gawked at the motor i have a few ideas of what is going on in there, but none of them are that informed, just a few educated and of course inevitable guesses. Which i wont bother to speculate about as they probably hold as much water as the story a "guy" at the track was telling me about how the Racepace inlet manifold made the inlet air travel in a vortex that accelerates and cools the air into the combustion chamber colder then ambient temps :ermm:
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/4/#findComment-3658374
Apexi made an RB26 2.9L kit but my money is on the fact that it still runs a std Nissan crank, most likely the RB30 crank and block. But like anything, its no one ingredient that gets you these sorts of results. Its probably a combination of displacement, turbo selection, tuning, cam size and engine building snf custom tweakign from hours of R&D....all topped off with a tune that allows for what has been screwed into the motor.
Excellent post
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/4/#findComment-3658387
Anything you can do with 2.6litres, you can do better with 2.9 :P
Well said
Impressive. Makes me wonder why Nissan didn't make these themselves. Like an RB30 with the anger of an RB26.
Congrats.
Group a rules
lol - if he moves to Sydney all the cars will start getting SBS (Sump Baffle Syndrome) that you blokes get up there far too often
Hahaha, not all of us :)
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/4/#findComment-3658704
Well Racepace have managed to effectively bait our breath, whats the story?? Is this a setup we'll be able to be told about or pay money for to get it for ourselves? Would be VERY interesting to see that car run on a hub dyno showing boost and rpm :teehee:
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/4/#findComment-3659366
Lithius,
I'm sure if you took your car to Benno and said "Give me that package" he would more than happily perform the required work to the car.
As for telling you how to do it yourself, I think you have got very little chance.
Ben has been developing RB engines for years and years and years. And that knowledge is the basis for his business.
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/4/#findComment-3659376
definitely move to sydney benno. merli's bill alone will keep you in business for a fair while. I'm a bit of a tight arse but have been known to break out the odd dollar too.
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/4/#findComment-3659667
My guess;
RB26 block (N1 perhaps)
87 mm bore (a good block will take 1 mm over no problems)
82.7 mm stroke (via any one of the forged cranks around, HKS, Trust Tomei etc) Could be tricky and save money by using an offset grind on the RB27 crank, but it is unlikely that it would take the rpm.
~120 mm rod (standard RB26 length as they are easily obtainable from a number of sources).
~4 mm raised gudgeon pin height (over standard RB26) pistons
I eliminated the RB30 block, some people don't like the requirement for a 4wd adaptor plate
I also eliminated the block spacer and liners, OS Giken style, as you wouldn't bother with RB29.5 when you can have RB31.
With the 8,000 rpm top end power the cams would need to be 272'ish maybe 280'ish on the exhaust, depends on the size of the exhaust valves used. Lots of lift, around 10.5mm or so.
That would facilitate some compression, say around 9 to 1, which would help achieve the nice power curve
Turbos, that's tough, GTRS (or a Garrett equivalent) would seem logical it has about the right power for them.
Then it's tuning, tuning, tuning
Them's my guesses.
Cheers
Gary
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/4/#findComment-3659719
Nice work Gary. I'm pretty sure a lot of that is wrong though. Except for the last bit.
But then the only person who really knows is the big fella. Even then I'm not 100% convinced he even remembers what has been done. Because every time he's done something to the car I've returned to find he's pulled it all apart again. LOL
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/4/#findComment-3659882
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
