OK guys been a while, new update.
The car has had a big fuel system upgrade which includes:
1000cc Rochester Injectors (all new injector plugs and wires)
Billet fuel rail
SX Fuel reg
Nismo lift pump
Twin 044s
Surge tank
Mesh fuel filter
Fuel lines are now braided with a few bigger hard lines.
Also had my old Profec B II fitted which was a huge improvement over the Haltech one.
Boost is now alot better but still tapers off a little.
Now who would of thought you could get this much power out of a GT3076???!!!!
Im extremely happy with the result. It has great response and still punches out an impressive number. Its almost unbelievable.
Nice work Nytsky.
Interesting to see the .82 worth 7ish rwkw extra compared to the .68 HKS (all dyno's being equal of course) at 23psi.
What sort of extra timing was the car happy at with E85?
Holding boost a lot nicer now too with the controller :laugh:
Unfortunately, for the first time ever i was not present when the car was tuned :geek:
In a few weeks ill be going back to do a back to back comparison with the screamer pipe on so ill ask then.
3037/3076 definately good size turbo for the 25 :laugh: especially with E85 on board.
  • Like 1
Its the ultimate turbo for the RB25.
Full noise by 3800 and all the way to 7800 :geek: Very meaty power range.
Yeah i hear ya just wish my engine bay looked half as good as yours :laugh:
wow sleeper much!!!
Haha yeah still running standard zorst and inlet mani's and engine has not been opened as yet touch wood .
9 months now on E85 and this power touch wood.
Edited by RB25DETS2
  • 2 months later...
5:45 AM ..finally finished reading this thread. It's been an interesting read ...much like a good car action movie without Nicholas Cage in it, albeit a 6-7 hours long one. Congrats on the final outcome mate, sounds awesome.
One quick question before I head off to sleep .. this has been bugging me for the past 5 hours or so. 1 + 1 = window. Someone please explain that to me (in a way that you would to a retarded child)
Can we take it as granted that an R33 fuel tank system is sealed well enough not to let any significant amount of atmospheric water in ?
It will be interesting to see what additions the General puts in their flex fueled Commode door's fuel system - if we ever get beyond the "its here next year" thing . E85 also has to be much more widely available than one servo and the oil co's will fight tooth and nail to keep it out .
A .
To my knowledge it has the breather at the filler to let air out as fuel goes in, aswell as the overfill tube thats let fuel out if you overfill the tank.
As far as the E85 Commo goes, they have just released their new 3L engine that is suppose to rival the Camrys fuel economy. I have a felling that this release will push the E85 fueled cars further back :)
Side note: The car is being prepped for this Sundays track day at Oran Park, if you have never been and would like to attend i highly recommend getting out there and having a go. There are alot of spots still available and you can pay on the day :)
The day is not a timed one, it more about getting out there and having fun in a safe environment.
Hi all,
Last November my car had an "incident" with a fence,and while waiting for it to come back from the smash repairers i deceided to go all out on the motor.My focus is reliability and efficiency,aswell as some nice streetable power.Every week since then has been like xmas,as pressies arrive at my door.
The last parts have been ordered and will be arriving next week.List as follows:
CP pistons(9.0:1CR) 20thou over
Spool rods
Cometic 1.2mm MLS head gasket
Nissan gasket kit
Tomei valve springs
Tomei 256 Poncams
Tomei oil gallery restrictor
JUN crank collar
Custom head to sump oil drain
N1 oil pump
Greddy plenum
Greddy throttle adapter
Nismo 740c injectors
Nismo fuel pump
Nismo engine mounts
ARP head,main,rod and exhaust studs
ACL Race series main and rod bearings
Splitfire coils
GT3037 .82 turbo (has the slotted cover for that T51r sound)
GCG Stainless highmount manifold
Turbosmart 38mm Ultragate
All controlled by a Haltech E11v2.
The block and crank will be cleaned up and prepped (honed,linished,balanced,grub screwed ect)
Still trying to decide if im going to wrap or coat the manifold? Also im looking at buying a new crank collar.Is it worth getting one?
Please give me your thoughts and all suggestions welcome.
Ill be posting some pics as the build progresses.
how are those ev11's compared to a power fc
Edited by Endless 32 v-spec
just read the whole post very interesting read and got alot of information out of it, im in the process of bulding my r33 im aiming at around the 300kw mark on my stock motor , see how it goes in at the tune soon, hoping the motor lasts for abit while i save money for a rebuild where I can push some more power like you have, well done it was a great project
That wasnt water :)
Had pretty bad blow by issues . Filled the catch can the blew oil everywhere after the first session.
This only happened when i was revving past 7200rpm.
The latter sessions i was changing at around 7000-7200rpm. Got a bit of oil vapour but not like the first session.
Then when Stu and i were battling the gearbox finally had enough. Spare going in tomorrow.
Loving the swaybars and slicks though. Normally i get no traction in second gear, but with the slicks it just sticks to the road with the G force tearing my face off ;)
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
