Total washout today, sat on our arses till 4pm.
Let us out for restricted laps, somehow blew a coolant hose off when on the gas one lap :(
Then found the oil cooler leaking pretty bad once on the garage. Going to use a 180 fitting to bypass it and throw this cooler in the bin. Pretty bad quality for an Earls item, both fittings snapped off in the past, the brazing is just really bad.
Anyway, hope to be fixed in the morning for more aquaplaning :rolleyes:
Here is a skid from the other day.
Took it back to Earls when the second fitting snapped off, Martin wouldnt replace it because he said I should have come when the first one snapped?!
I said the brazing is obviously not strong enough as both fittings have snapped off... No dice.
Brand new cooler, both fittings broke off on first use, no refund?
Pretty open and shut, try once more then take it to fair trading.
Only questions I'd have are were the hoses supported well or able to move around fatiguing the joint? And when the fittings were done up was a second spanner used on the cooler end to make sure it doesn't twist.
Crap summer to be doing skids in a high power car, eh?
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
