Western Australia have one of these topics and I wondered if Vic would like one. If you don't want it, it will show by lack of posts and drift away into the 3rd page... noooo.
I will begin with last night on Hotham Road, saw in my rear view mirror a purple or black r33 GTR with a nismo sticker on the windscreen.
And also a 33 gts25t off hotham road. Which i sat and looked at for 20 minutes whilst my mum was talking on the phone.
  • Like 2
https://www.sau.com.au/forums/topic/210524-spotted-thread/
hmm im a lil confused, but anyways saw a 32 gtst pulled over by cops on the princess highway at around 11:00pm tonight... :D made me drive past extra carefully
yeh i saw that too. hope he didnt get done for ne thing major
https://www.sau.com.au/forums/topic/210524-spotted-thread/#findComment-3722853
nah one of the admins locked the old vic one, was over 500 pages
so i just removed it and made a new one - fairly std procedure
Wasn't me but i understand the motivation behind it... so I'll let you in on it.
Basically, like all wasteland threads (and others), they eat up the search/read parts of the database.
So removing them helps keep the forums fast and useable for everyone.
Whilst not 'ideal', its all we can do and I'm sure you know what I mean :D
https://www.sau.com.au/forums/topic/210524-spotted-thread/#findComment-3722886
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
