Spotted a White R34 - plates WCI-XXX - at roughly 4:15pm on Thurs at the intersection of Abbots Road and South Gippsland Highway, Dandenong South.
Spotted a Silver R33 - plates CRZY33 - at roughly 11:15pm on Fri at Shell on Princes Highway, Hallam.
spotted CRZY33 on stud rd this afternoon
lol yep they were both me :thumbsup:
spotted a silver r33 gtr (plates GTARRRR....or something) doing the laps down chaps......3 times.....lol
I saw you cutting chap laps last night, no idea what time
Also say a poxy green R33 with clear tail lights and neons. Almost made me bring up my last 6 beers.
saw that green r33 on lygon st last night - :thumbsup:
silver r33 on princes hwy last night im pretty sure it had sau stickers on rqw
blue r34 on toorak rd shortly after
thursday/friday saw a black r33 on taylors rd had white rims and sau stickers on rqw
i always spot sau members and none of em are on the forum :yes:
yeh just came back from crown wanted to avoid princess at all costs with the new mods so i cut through chaps Lol
also spotted that green r33 with the tailights....had the green neons parked on the side..... :thumbsup:
not sure if it was u but i gave someone in tha silver r33 the nod......
also spotted that green r33 with the tailights....had the green neons parked on the side..... :D
Nah not me, I was wandering along the footpath. Def not in a state to drive last night.
spotted nick on sydney rd last nite pretty hard to miss those headlights lol
i didnt see you cause u in ur cuz's prelude
and yes i love my headlights :dry:
spotted Rimon on taylors rd about 6ish
ghey spec with no front bar, its only tuff wen u got manual cause u can say u had drift damage
sif can do anythign in an auto :D
was driving behind a silver r33 with SAU sticker with plate "PSI-033" on nepean highway heading towards the city at about 5:30pm
THEN
was driving next to a silver s2 r33 with SAU sticker with plate "KADANE" down lower dandenong road at about 10:15pm
Yeah that was me.
Could tell you wanted to have a bit of fun but I had just picked up someone from hospital so I didnt want to shake her up.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
