Spotted a Red / Maroon R32 - around 3:30am at the intersection of Don Street and Calder Freeway, Bendigo? - was driving the AUSfast truck.
Also spotted a Silver R32 with a FMIC - around 7:00am waiting to turn right onto Hallam South Road from Princes Highway, Hallam - was driving my GTR (finally!)
spotted a drug/booze bus pulling up at Edgars Rd Thomastown just off the freeway exit.. about 5 mins ago.. probably going to setup on the blind curve there.. last time I went through one I got defected!! So be warned..
Will probably be alot of them around tonight caus of the stupid Tiesto concert..
Spotted "SKYGRL" (?)... ...a White 34... ...On Heatherton Rd, Crossing Westall Rd around 6:30pm...
And a Blue 32... ..."BLUR-32"... ...On Princess a little later...
Stand out for the week was the chick driving the White 32 GXi(?)... ..."POZ-xxx"... ...Parked next to me at the Springvale Maccaz on Wednesday and then followed me turning right out of the Springvale Rd exit and down Springvale Rd for about 2Ks...
I got to get more "Spotted Cards" to hand out... ...I felt like a dick when I thought of giving her the URL scribbled out on a piece of paper...
So I didn't give it to her... :(
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
