LOL!
That's a funny one Beza!
L1VLYF in a Silly-car...
Whatever...
lol sad to say i went to highschool with that guy, was the year below me, now he's like a manager at that kfc.
I think the respray was worth more than the car.........
Edited by tkdbboy
LMAO!
Must have sold a lot of fried chicken to fund that paint job, let a lone to do anything to the car.
LMAO!
Shut the f**k up jamie, me and bez know Alfy (guy who owns it) and he is an awesome guy. Why dont you say shit about his car to his face and we will see who ends up on top.
Time to throw down bitches.
LMAO!
id be careful what you say, this isnt a thrashing thread, some people work alot for what they got, unlike some who just get it given to them... keep it to the wastelands if ur gonna talk crap about peoples cars yeah mate?
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
