spotted myself driving home down high st road with some wank in a SS VE ute trying to stir me up. even if i wanted to drag him i dont think the whole 10m distance to the cars in front of us would have worked out to well. typical whiteboy trash sitting behind the wheel wouldnt know any better
Gotta love Knox!
spotted the new GTR Hilux in camberwell while getting a coffee today!
:D
Both mega FAILS!
While walking down Glenferrie Road to get my "Japanese" on I saw a white 34 (WQK-XXX) heading away from Princess Hwy...
Then when I was sitting down with my Japanese feast I saw a white 33 with personal plates starting with an "S"... ...Didn't get it all because of parked cars...
Then a bit later the white 34 went back the other way... ...I didn't get the times because I was too busy eating all that raw fish...
And while stumbling home and crossing the inbound lane of the Princess Hwy another white 33 (S2?) stopped in the middle lane... ...Because the lights commanded them to stop...
Spotted a black R32 with SAU stickers tonight on Springvale Road at like 6:45? It was heading towards Springvale. Maybe it was Patrick? :nyaanyaa:
Then spotted a white R34 crossing Wellington and Springvale around the same time, heading towards Rowville. Maybe it was Ashneel? :(
Yeah that was me. Where were you? didnt see any yellow r34?
Was driving alongside a blue r32 gtst with p-plates on ferntree gully road and stud road. Didnt even acknowledge me driving next to them :(
Also driving alongside a white r34 gtt with sauvic stickers on wellington road and didnt even give a look.
No love in the skyline community :(
I was heading towards Glen Waverly, I didn't see you until the last minute :nyaanyaa:
I saw you just before I got to Wellington Road :(
spotted a dickhead on the dandy bypass around 2am. Black r32 gtr, doing at least 170 in a drag meet, good on ya mate hope your proud of ya self and your dickhead mates. I bet you'll be the first to cry harassment when you get pulled over also!
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
