Spotted a black 180sx with r32 rear taillights :wub:
It tripped me out cause I saw it from behind, sped up to catch up to a fellow r32 and it turned out to be a 180sx :(
Least he gets points for style :wub:
More like points for imitation. R32 lights for R32s only please! Although it is the sincerest form of flattery.
Saw SKYL1N on Maroondah Hwy around 2pm ... with a cop on his tail!
Ha, from your signature we have two things in common - Robert Jordan and David Eddings!
Apologies for the off topic.
:P Love them, great books.
On topic, saw tufr32 carpark @ essendon :P Second time i've seen it there. put the spotted card to use :P
Spotted a fellow skyliner after i dropped the mrs off around 9:15pm on dalton rd in the form of a (midnight??) purple 32. He had the same eccs rear bar as mine. Never seen my rear bar on any other car in the whole 4 years i've owned my car until tonight. The car looked very good. I gave a thumbs up at the lights and we had a bit of fun on the ring road before splitting ways at the sydney road turn-off then i headed back home to geelong.
Yeah that cop followed me from box hill to middleborough, then i turned off right and he kept going
was rolling down every hill and doing 69 kms the whole way.
