Spotted a black 180sx with r32 rear taillights :wub:
It tripped me out cause I saw it from behind, sped up to catch up to a fellow r32 and it turned out to be a 180sx :(
Least he gets points for style :wub:
More like points for imitation. R32 lights for R32s only please! Although it is the sincerest form of flattery.
Saw SKYL1N on Maroondah Hwy around 2pm ... with a cop on his tail!
Ha, from your signature we have two things in common - Robert Jordan and David Eddings!
Apologies for the off topic.
:P Love them, great books.
On topic, saw tufr32 carpark @ essendon :P Second time i've seen it there. put the spotted card to use :P
Spotted a fellow skyliner after i dropped the mrs off around 9:15pm on dalton rd in the form of a (midnight??) purple 32. He had the same eccs rear bar as mine. Never seen my rear bar on any other car in the whole 4 years i've owned my car until tonight. The car looked very good. I gave a thumbs up at the lights and we had a bit of fun on the ring road before splitting ways at the sydney road turn-off then i headed back home to geelong.
Yeah that cop followed me from box hill to middleborough, then i turned off right and he kept going
was rolling down every hill and doing 69 kms the whole way.
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
