Clean red SVD R31 with white wheels and personalised plates following me, this morning along Warrigul Rd.
Saw a white R34 coupe (not sure if it was a GTt or GTR from afar) along Dalton Rd Thomastown around 9am.
Spotted...
  1. white r32 gtr - dynon rd
  2. gray r35 gtr - also on dynon & followed it to droop st
  3. whole passels of skylines @ chasers
  4. white r33 - droop st/geelong rd
  5. burnt orange 350z - also on droop st
  6. forest green s14 - ballarat rd
  7. another forest green s14 - followed from mt derrimut rd into brimbank gardens
:down: was bored going home today so was playing spot the jap imports
Wine red R33 boosted it past me along St Georges rd.
I caught up at the red light - he kept looking forward....
Big NISMO sticker across the rear windscreen
I feel no love.
Why show off and not look at me? You obviously proved you can reach a red light faster than me.
on the other hand i cruised with a sexspec little fwd thing. so much kit chrome and candy green that i couldn't tell what it was, but it was turbo, and fast. took it very easy despite four or five commodores trying to race the both of us all the way down stud rd from knox. gave it a little hit to 80 at cheltenham rd from chandler rd lights, gave eachother a wave, and he turned off, i went home. guys in r33's are massive dicks in comparison
I feel no love.
See my diagram up top for an explanation!
I think I've had one R33 acknowledge me, ever...and that was the night I picked up my car :P
What pisses me off though, is that you know they know you're there...it must take some control to just keep looking forward like that and pretending you don't notice.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
