Spotted wanzi lastnight...at my gym lol. Saw your car parked as I was leaving, stopped to say hi but you weren't in it...yet your parkers appeared to be on? Do you know the other white Skyline that was parked behind you?
That was me :huh:
yellow evo 7 out near EFFING / sommerton, i think it was nick
was about to catch up and give a wave but you turned off
not sure if it was nick or not, looks about the same as your pic on stalkbook
Spotted Kris along Dandenong Road at about 4 am. Was going to say hi but had to go after that motor bike. Couldn't find it though. Better that way as probably would have been pursuit.
I liked the green R34 that was with you too.
lol that was you?? Was wondering why a cop car was following us haha
and no, male. Was a gtst. Only chick with a white 33 around that area that I know of is me :P
He would have ran Graham. His bike is a 1000cc and his licence plates are covered up
Haha yea joshs car is nice too! Damn I didn't known was you! Saw you look at me when u did the youturn. Was thinking we were f**ked haha
I was thinking it was strange that 5 odd cars didn't give way to a marked police car with it's lights on :P
My fiance has a white series 2 gtst and we live in Aspendale. So there is one other :P
:huh:
VSPECT everything ok?
hey mate...nice seeing you again...ya everything good...he just wanted to know why i was staying back at the interesection..n i was like talking to you..lol..he also thought my car was too low so wanted to check :ermm:
Birds where were you today? didn seem to catch up to us guys...got home alright?
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
