saw a dark 34 non turbo P plater with a GTR badge on the rear (fail) about 4 something today on Melton hwy melton bound. Looked like you were trying to drag the red shelby mustang..... good luck with you future endeavours lmao!!!
seen him around Melton lol little wank
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
