Black 35 in Docklands today.
And off topic, black VE SS ute with front driver's side completely smashed in at corner of La Trobe and Spencer being picked up by a tow truck. Played chicken with an old white Corolla and lost by the looks of it.
Spotted a gorgeous black R35 GT-R with personalised/custom plates, big aftermarket wheels and aftermarket exhausts(?) cruising along Clarendon St tonight. Sounded absolutely hot, even on low revs :):)
Also an assortment of other Skylines as well spotted in the same area throughout the night. 2x black ECR33's as well as a silver ECR33 that was particularly loud.
Silver CPV35 parked under bridge near westgate city-inbound with hazards on around 11pm? Hope all was ok...
Edited by GT32
