keep seeing a purple 33 gtr on dandenong hastings road heading south, think it has bronze/gold wheels.
its either really dark purple or black.....
Edited by Plattsy
Spotted you car once again...same spot same time...
then heard you needed new breaks ? damn dude!
LOL.. nah. it only squeals when cold!
for like 5 secs. silly nissan caliper design, apparently needs more grease on the retaining pins.. not that it affects me, started with the new rear pads.. was worse 3months ago.. they're way better.
no more rbpowa stagea yeah?
oh lol well it must be! ive seen one other red r33 s2 around but it had silver wheels unless it was the same one and changed wheels or the sun impaired my vision!
Yeah I've seen another red 33 S2 with stock silver wheels on it, I think he was as amazed as I was cos he was like :O as I drove past, then waved!
Eltham local? Noice car! Grew up in Eltham..... Monty and now Kangaroo Ground. I have a white R32 GTR Vspec and Dad drives a white Focus RS around too. Will be good to say Gday.
Wash your Car!!!! It's filthy today.
Nice, I think I've seen the Focus around a few times.
I know, I know.. haven't washed her in ages :(
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
