White stagea with SAU VIC sticker at 7:45pm friday. Parked on road in ferntree gully
Also a red r33 with roll cage and Motul decal + other decals on the side. Looked like a d1 drift car?
Saw the motul 33 on station st turning up edithvale rd that day.
Saw some chick P-plater driving a neat white 34 GT down the windy mile the up Chute St into Diamond Creek this arvo @ ~5:40
Anyone here?
I was on the red R1 who passed you going into the Stone St roundabout.
To the cute blonde girl in the White R34 NA outbound on Nepean Highway this morning at 8:30...
You looked good.
Car was a bit meh, Green wheels? Really?
HAHAHHAAHA what does it matter, she was cute right? :P Always a thrill to see a good looking chick drving a skyline.....still waiting for the day i see a girl driving a monster R34 GTR......
SPOOL Yellow S15 this morning on Reserve Rd Cheltenham, used to see it around a bit but not so much lately... still looks good :)
Cool thats my old car. Still using my old plates too. Nice to know its still running.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
