hahah, i remember u now.. ur the guy who thinks the 4wd system on a gtr has almost no losses hahaha yer good one mate
everyone here knows u dont know anything at all.. so why even bother puttin in ur say when its always bullshit anyway?
maybe u should just sit back, be a mod and just let the experts handle this department :D
Funny that the whole drivetrain loss has been proven with back to back results on 400awkw+ :ninja:
I don't think you've searched and read them yet have you?
I wouldn't call you an expert at all, far from it.
well it hasnt been proven :D
its actually been proven by the guys who invented measuring units.. u know.. those guys called ENGINEERS??
and uve been proven wrong as well by many other forum users so dont bother arguing dude..
the day a drive train has minimal losses, will be the day that fuel usage drops to like 2lt/100 in a 300kw car
but as it stands by today, the loss is about 30% and i wont bother gettin into it with u, because uve already been proven
wrong by everyone else on this forum :ninja:
The exhaust gasket between the dump/turbo was reused.
Im running standard boost 10psi and always have. Just full exhaust and smic thats it.
Cheers all for the comments, ill replace both gaskets on the front/dump and see if that reduces the sound.
Thanks :laugh:
after you do that please let us know whether it still makes the sound, double check it too just to make sure it's not leaking, so we know if there really was a leak or not for reference..
i guess everyone who's posted here are just trying to help out, everyone's got different thoughts from their own experience, hence different approach and different comments..
everyone should be entitled to have their own say, lets just read it carefully to make sure there's no misunderstanding, and respect it, if you do think otherwise, just say what you think but i dont think there's a need to aim your fire at anyone if their opinion's different to yours.
It's fine.
Yes of course you will loose low end response. You've got a much bigger surface area on your new pipe, so it will radiate heat alot quicker than the stock unit, reducing exhaust velocity and therefore torque. However as revs increase, the extra flow outweighs this, and you begin to make more torque.
The noise is probably normal. Turbos make sounds like that. :D
It will be a leak of some sort.I had this exact same dump pipe on my car(this exact one in question) i had no weird noises at all.The only noise that was different was i could now hear the turbo spool through the thinner wall of the dump compared to the thicker stock one.
EDIT: Maybe this weird noise you hear is the sound of the turbo spooling??? Just louder now that you have the dump pipe in.
well, I bet its the gaskets between the turbo and manifold.
Nismoid is right, the head to manifold gasket makes a tractor sound.
The Manifold to turbo gaskets make the high pitched sound. How do I know? Because mine is doing it, my studs are stretching and I need to keep tightening them.
There is even a little brown spot where its leaking. It sounds like a kettle, or like how the redneck bushman put 2 gunm leaves together and blow through them and make that stupid sound.
Thats what happens when the gaskets are loose - they make that squeal.
I'm in the process of removing the turbo and changing mine too.
Bumblebee, you may say you have done 1000's of cars, which I doubt you've done 1000's of Turbo charged Skylines, but do you hae one that has had a turbo upgrade, makes some power, and is actually doing it all the time to know what you're talking about?
I doubt it.
I hope you are not mistaking this noise for the louder turbo spool noise as a result of fitting this dump pipe. :D
sound doesnt worry me, i was more concerned about the less response in the lower rev range, but im used to it now hehe
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
    • You sir, big win tonight. Precision never supplied compressor maps in the past and Idk when they started, but it seems they only offer for a few of the older gen2's which is exactly what I have. I punched in some numbers and seem to have gone with the wrong turbo. 600-700whp isn't in the most efficient area and is close to the choke line. 800whp is well off the map. Punching the numbers into a 68mm gen2 turbo map is bang on in the center. Here I was thinking going smaller would shift the power band down, but in reality it would just make it so much worst due to my rev limit. I would have never thought.
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
