i think Castrol Syntrax is another good alternative for the diff.
Nulon Engine Oil Flush. What are you thoughts on this guys? Worthwhile? Waste of time? Just plain dodgy?
http://www.nulon.com.au/products.php?productId=eof
I believe Martini make a similar product, but damned if i can find the name of it...
I am about to do my first oil change and I thought I would just spend the money (car is about to spend a session on the dyno getting tuned) and get some Motul 300V. Trouble is it only comes in a 4L bottle - is this enough to do a full oil change in an RB25DET Neo? How much oil do they take?
Also I will need a new filter, are the generic Ryco etc. good enough to use? Do Repco and similar stores stock the suitable oil filters for RB25DET's?
Any help is greatly appreciated as I am hoping to pick up the bits tommorrow! :wave:
i can answer this was some first hand experience!
Motul 300V slightly better than Mobil 1 0w40
none-the-less, Mobil 1 is still a very good oil. 0w40 is not too thin, well unless if you have a very old car, or perhaps doing some serious track work. But street driven, Mobil 1 is more than fine ;)
I just did my R34 on saturday, Mobil 1 0w40 (would have gone Motul 300V, but i was doing a rather major service, so next time) and it took 5 quarts. 1 quart = 950ml, roughly. So it took 4.75Litres.
Sorry, but you're going to have to buy another 1L bottle. 5L is about perfect. This was with an oil filter change as well.
I was told to stay clear of Ryco. I used OEM filters on saturday (fuel/air/oil). From Nissan, it was about $11 or $16, can't remember which, but it was cheap. Any dealer will have it in stock as it's not a special "For R34's only" item.
Hope that helps!
Oh, car is running slightly smoother, i'm pretty sure it's quieter as well. The lifters on RB's are usually fairly noisy, but the tapety noise of the lifters has reduced a little. My car seems to be in very good nick the further my mate and i look at it (he's a mechanic). So i don't think i have significant gains to make in terms of 'running better' with a good service. But the Mobil 1 has "smoothed" out the engine somewhat, and has made it quieter as well.
cheers,
daniel
none-the-less, Mobil 1 is still a very good oil. 0w40 is not too thin, well unless if you have a very old car, or perhaps doing some serious track work. But street driven, Mobil 1 is more than fine :nyaanyaa:
Hope that helps!
cheers,
daniel
Thanks for that. I think it is so stupid they sell the 300V oil in 4L containers. I know it's probably to make you buy 2 but it's probably just going to make me choose something else instead. Are you sure you can buy 1L bottles of 300V as well?
i just assumed you could :nyaanyaa: obviously you can't then.
So looks like it's 6L's for you, and just buy a 4L next time and then start the cycle again, 6L, then 4L, etc :nyaanyaa:
I bought 6 quarts of Mobil 1, but have 1 unopened bottle left over, and some of my Redline oils are left over as well.
So yeah, go 6 this time, and just keep the extra for your next service. 5000km's shouldn't take too long. The oil will keep :laugh:
cheers,
daniel
EDIT: there are some real oil gurus in this thread, so hopefully i haven't sent you down the wrong path. But i looked into this a fair bit before my service, and i hope i'm passing on knowledge unblemished as it was given to me :laugh:
i just assumed you could :laugh: obviously you can't then.
So looks like it's 6L's for you, and just buy a 4L next time and then start the cycle again, 6L, then 4L, etc :)
So yeah, go 6 this time, and just keep the extra for your next service. 5000km's shouldn't take too long. The oil will keep :D
cheers,
daniel
EDIT: there are some real oil gurus in this thread, so hopefully i haven't sent you down the wrong path. But i looked into this a fair bit before my service, and i hope i'm passing on knowledge unblemished as it was given to me :)
Thanks for that. I actually ended up buying 5L of Motul 8100 5W40 100% synth instead. Will do the oil change today :)
  • 1 month later...
When i get into the monthly supersprints i will start using mineral oil. penzol or something!
i've been recommended by a well expreienced race engine builder
Don't be silly.
The only reason people occasionally recommend mineral oil is that for reasons partly unknown some synthetic oils do not agree with old fashioned push rod engines. Specifically the cams & cam followers suffer. It is sometimes blamed on the amount of friction modifiers in the synthetics & the large surface areas of the valve train components in push rod V8's.
Old fashioned motors are a world away from your RB whatever. Use a good quality synthetic oil of appropriate viscosity & overfill it if you are going to the track.
lol, andrew, that is one of the funniest things I've read in a while!
Motul Chrono 300V, or the next one up if you are worried.
as for the monthly sprints are you running this sunday at EC? I will be there.
Thanks for that. I actually ended up buying 5L of Motul 8100 5W40 100% synth instead. Will do the oil change today :D
the motul 8100 is ok, but it's not a full synthetic ester oil like the 300V is.
I know bugger all about anything, but I know the chrono 300V is damn good oil. for the money I think it's well worth it. and yeah, you can buy a 4L and a 2l. then next time you just need a single 4l. :)
Actually Baron I have had people knock back offers of a top up of Mobil 1 for their old school (in this case Alfa) motor because they were too scared to put a synthetic oil in it. Believe it or not....
yeah, but he's not driving an alfa! he's using RB26 power. which to me means running a mineral oil is nuts.
depends on the car though, you are right. but we are only talking about one type of car here. ftr we use synthetic in our alfa, but it does have a built motor in it.
stay away from castrol edge and penrite syn 5..... turns to water in rb's.
my 2c's :whistling:
oh yeah pay no attention to the oil test done in street commodores a few months back which royal purplue won.... it was a crock of shite, they used grease testing rigs to test oils... morons.
Edited by URAS
I just had the Motul 300V chrono put in. Engine definately feels smoother. Didn't do much to quieten the tapping sounds though.
What I was most impressed with though was the Red Line light weight Shock Proof gear oil. I would recommend this to anyone with worn syncros and/or gear box notchiness. Think twice before getting a reco box and try this stuff. It's gold! :)
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
