Things like zinc additives do help add kind of a lubrication effect because of the "softness" of the way the zinc attaches to the engine parts, but this effect is dwarfed by the actual lubrication effect of the oil.
On the dark oil, birds said pretty much everything I thought of lol, he has a habit of that :P, but he's very right that it takes a tiny amount to stain the oil black, and that the oil absorbs the carbon into it's structure, the carbon can't really escape this to build up anywhere. The oil can take an awful lot of carbon before reaching saturation. It's not like once the oil is resting after a change the carbon all falls to the bottom of the container, it stays in the suspension because of the particular physical chemistry effects the designed additives have.
This is what Motul France recommends.
that is interesting that they recommend a 5w30.... motul aust recommend 5w40 for RB's
also the sump capacity is wrong. they state 4.5lt when it's 5.5
Haha Galois was waiting for your backup :P
Trying to find a clear cut answer on how much oil the gearbox takes is just as bad. In the end I just fill up oil until it's within the safe dipstick range, or in the case of gearbox and diff, fill up to the filler hole.
International recommendations = pointless. They are based on a completely different climate. France is cold as f***, it's no surprise they recommend something thin like that. Stick with the domestic arm if you're going to follow manufacturer recommendations.
Haha beat me again, I have to be quicker
Hi Guys,
I like this thread but its toooooo long for me to find what i am looking for.
I have a R31 with an Rb30/25 setup. R33 manual box and Full spool Diff.
What grades/brandes of oil is recommended for my setup? My usage will be 50% track 50% street.
I currently run penrite but going through some of this thread i didn't see Penrite get much mention, i;m more than happy to try others. I am looking to buy in bulk as well.
Hi Guys,
At least read the first post...
Hi Guys,
Engine will most likely be the same as for everyone else. Likewise for gearbox, except not so much info on that. Go with the recommended penrite syn or castrol if you want cheaper and throw in a bottle of nulon g70 additive (or is it g90, i can't remember, one is the replacement for the other).
No idea on the diff.
There is a transmission and diff oils thread in the drivetrain section but it's not quite as qualified as this oils thread haha
I have been reading this threat for a while now and can't figure it out and I'm new to the turbo piston scene, I just got my 2001 r34 GTT basically stock and want to do an oil change but not quite sure on what oil to get? Any suggestions guys? It's got 63000kms on the clock, is 10/30 ok? Street driven but I have a heavy foot haha lol.
You can't have been reading that long mate, that engine/car has been discussed on pretty much every page of it. Read the previous couple of pages and you'll find it there.
good god i must have been reading this thread for about 2 hours. Might as well add my 2 cents i have been using Nulon 15W-50 (street and track performance) for a few oil changes now and it seems to be ok. I was thinking of giving Motul a go and after reading all the people bagging nulon i'm leaning more and more in this direction. I havn't really seen the 15W-50 mentioned everyone seems to use the 10W-40, i was told to use a 15W-50 by the mechanic at Chasers so thats what i did ending up at nulon because it was 15W-50 and 'synthetic' and reasonably priced. Plus its good to support local companies (so i'm told).....after reading all this though my opinion hasn't really changed, when next oil change is due i will check out price of Motul otherwise keep with the Nulon.
Are these more specialised mechanics/builders, or your average falcodore servicing guy?
I've had a few mechanics who may be competent at the regular cars but I'd never take something different there.
Edited by Galois
10w40 is fine for most r34 gtt's but if yours has low kms you'd probably be right running a 10w30
i use the gulf western syn-x 3000 and have done for a while now, its good, its cheap but it just doesn't last as long as the sougi (motul 300v equivalent) did
but for $33/bottle you can't complain
its a 10w40 btw and i run it in a s2 stagea (rb25 neo with 108,000kms)
*then
Then what - just use it. Pretty sure 8100 only comes in 5W-40, I have it in my car now for just over 2,000kms and no problems. Car runs smoothly, oil has turned dark brownish, can't notice any issues. I'd recommend 8100, either one.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
