I just went and bought the Gulf Western SYN-X-3000, damn its so cheap at 30 bux, im feeling guilty lol and wondering if I should go n swap it for the 'better?' Sougi M5000 which is what I have in my engine currently...
Double post damn iphone.
Edited by rondofj
In the $30~ range I would only touch GW or Penrite. If you put something in like Magnatec then I would say to swap it out immediately for something better.
Oh ok, just bit paranoid cos it ( GW SYN-X-3000)looks kinda generic, but have read on hear that its pretty much the same as the GW Sougi M5000 which is only 50 bux.
Edited by rondofj
I use Sougi S6000 (still have supply for one more oil change) and as far as it went with replacing my regular oil Motul 8100 X-Cess, I couldn't fault it all. Good oil pressure when cold and hot, built pressure quickly at startup, still looked good after I dumped it at 5000km (no sludge, was black but didn't stink of fuel), idled smooth as it did with Motul (often I had to check my RPM while waiting at traffic lights as I couldn't feel it idling, kinda felt like the engine had stalled).
Years before I even heard of Sougi, I had some cheap GW XMP ($5 something at supercheap) lying around I never got around to using as I had a 4 cyl shitbox before my skyline, I offered to do an oil change on my neighbours car (4cyl shitbox). It was a completely different animal putting the oil in, before it violently shook, could feel it through the steering wheel really bad just idling and the loose plastic interior panels sounded god awful not to mention the engine sounded like shit. After the change, engine sounded healthy again and idled smoothly which god rid of that nasty vibration.. I wasn't expecting this at all from what I perceived as nasty $5 oil. Even my neighbour thought I did more than just change the oil and filter.
These 2 experiences personally give me have confidence in the GW brand, I only use it in my skyline because others have used it with success.
If I run out of S6000 and Syn-X 6000 isn't available nearby, I'll give Penrite's 10 Tenths range a try, if that doesn't work I'll go back to Motul.
Nothing wrong with running Syn-X in your car. It is technically a "better" oil than M5000 only because it meets later specifications (SM vs SL from memory). It is IMO the best oil on the price-quality scale and I used to sell lots of 205L drums to mechanics who loved it because of how cheap and versatile the oil was. They all used it in their regular customer cars and upon return couldn't fault it. I'll still be using M5000 once I run out of S6000.
Birds that new Syn-X 6000 looks interesting. Not so happy about it being 5w though. I think it should have been a 10w40 oil as it's still going to be competing with the Royal Purple, Motul 8100 X-max 10w40 and the Chrono 300V. It's not a bad replacement for Sougi S6000 but it's annoying that yet another oil comes in a 5w40 only with no 10w40 option.
I was a little disappointed when I saw that it was 5w...don't know why they couldn't just do a full synth version of Syn-X 3000. I think they wanted a cheap oil that would appeal to all these late model cars asking for 5w oils. That said, I've heard there's very little difference between 5w and 10w, and that some oil companies will market their 5w as 10w and vice versa because of this.
Hey all.
Need some advice on what oil to run when using E85. Has it been covered before? I hear that because of the ethanol content a different type of oil may be required. Thanks in advance.
russ, we had a long thread about it in FIP.
I use motul 6100 15w50 as it is desgned for LPG and has good moisture absorbing properties.
to summarise what we worked out, you can use pretty much any oil if you change it long enough. if you dont want to change it after every track day dont use 300v
a semi syn (like 6100) is a good idea as the mineral content will have good moisture absorbsion.
esther based oils are not great unless you change them after every event, as they end up with the moisture seperate from the oil.
there are specif oils that were reccomended, however i cant remember them atm.... i'll link you the thread when i see it
All of the Penrite HPR oils are fully synthetic now, what are your thoughts on this?
Would you switch from Syn to HPR? Or keep going with the new Syn (Ten tenths?)
I am trying out the HPR15 for my RB30.
yeh i been wondering the same..i just put HPR10 in as its cheap and only really seeing street duties and i was sick of spending 80 bucks on oil just to drop it 2000kms later cause it hadnt been driven much..
but wether or not its designed for engines pushing double factory power is something im unsure of as yet...Might be better off with the Edge :unsure:
Stock rb30 = coles motor oil changed every 50 000km's and it still wont die....
ARTZ, the HPR will be fine, i used the old HPR for years and years at double factory power and when i pulled the motor apart it was immaculate. I cant see the new HPR being anything but better again. But then again I'm a big Penrite fan so i might be a little biased.
Well First cold start this morning with me remembering i have forgies but really noticed alot more noise than i was used to also noticed even at quarter temp some engine noise was still there. Once car come up right up to temp the car was fine. I was just using the royal purple 10w 40w and i have the HPR10 which is however 10w 50w so any thoughts id really appreciate it.
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
