Confused if I should go with Penrite Racing 10 10-40w or Penrite Racing 15 15-50w, Car has 81000kms on the clock with just the first stage mods, intake, front mount, exhaust, 12psi, power fc 211rwkw, thanks.
If your going to track or go for "spirited runs" in the hills i would go 15-50w.
I personally use Nulon 10w-60
No track anytime soon, but she does get quite a few "spirited runs", I thought Penrite was the way to go but just read some more and am completely confused, alot of negative for Penrite in this thread, I have been using Royal Purple 10-40, although oil pressure doesn't hold up with it, always pretty low after a nice run, also with their price hike on their oils I ain't paying $120 for a bottle of oil that I just dump every 5000kms, I'm leaning towards Nulon at the moment.
im using royal purple as well but no dramas with oil pressure, u sure its not a flakey oil pressure switch?
Ryco make a platinum filter, has to be changed after 5000 kms tho due to the super filtration. I ran one once. Seemed fine. But put full syn in and run 10,000 km intervals now so doesn't suit me
I changed to penrite 10-40w racing10 about 1000ks ago i'm happy so far good oil. I use a ryco filter not sure if they are the best, only other filter I've brought was a Drift one and it looked horrible. it had strange metal specks in it and on the thread. threw it away and got a ryco.
Edited by dyl33
I genuinely am sorry but could someone please guide me to a link regarding spark plugs? I can't really seem to find anything new its all from 2006-2008 and many differences and I don't want to turn this thread into a spark plug thread aswell, thanks.
Also, just curious as to what drain plug/washers you guys use? Magnetic or OEM. Just Jap is out of stock, and my local Nissan dealer is my last resort. Where else can I source these (OEM plug+washers)? Part No.?
Lol random post is random. Get BCPR6ES-8 (~$4 each) and replace them every 30,000km.
As for everyone else confused on what oil to get, use this: Penrite PREMIUM 5 5W-60 ;)
Hey man thanks for confirming that, I was leaning towards those plugs plus I'll be replacing them every 5000 kms better than the iridium crap I'm using atm and still having to change them every 10000 kms at $160 for the set, I was just unsure of the gapping, I have yellow jacket coil packs, thanks.
Edited by MrRx7s3
Haha, Iridium crap. I can't believe I pay $20 a plug for them to be useless...
If you are fouling iridiums or melting them you have other issues, and copper plugs won't fix that, no matter how often you replace them.
There are literally pages of threads on plugs, why here?
As I mentioned before I can't really find much through search for some odd reason, iridium aren't really suited for boosted cars as their tips are thin for one and also at high heat they tend glow and that's what makes them shit themselves and also pre ignite.
My car is runs fine at 40+ psi, perhaps it's the superior fuel I use? They (NGK's) certainly aren't as shit as you make out. Perhaps you are buying them too hot for your application?
Try a google search with skylinesaustralia (then whatever you want to find.)
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
