Most of the post is what they feel/hear/see/smell and nothing factual >_<.
How about this?
I changed the oil on my GT-R on the weekend. Out came 5L of 10,000km old Penrite Racing 10, in went 5.5L of Premium 5. It shut the head up on cold start (few seconds of valve train noise).
has anybody heard of the new oil type that motul are putting out now dany at garage 101 mentioned it to me one of there reps came around talking up a new race oil that is supposed to be super high quality unsure on the weights ??? motul swear by it and has backup from some of the fastest race cars around that are using it . apparantly bit pricey compared to your normal 8100 motul or whatever it is i havent used motul in a while i cant remember what the names are
does anybody have any insight into this ?
did you have the valve train noise on the previous oilchange?
How about this?
Nope.
It was a tongue in cheek post. The noise came after some thrashing. Oil was getting old anyway. The point is, any decent oil will protect your engine, provided you replace them (and the filter) regularly. Since most of the time my GT-R is putting around in economy mode, I change the oil every 10,000km (hence using $75 oil).
  • 3 weeks later...
So I have being using GW Synx-3000 semi-syn oil for my car every 5000km or 6 month for a while & I'm wondering if I go with a full-syn oil would I be able to extend that interval to 10,000-15,000km or every 1 year?
Reason being I'm too lazy :whistling: & the Car (basic bolt on mods) is currently used by my mum driving back & forward to work, which is only ~6km or so & probably never sees boost (besides the time I take it for a drive).
Edited by Mayuri Krab
short distance driving is normally considered "Harsh" driving by most manufactures, which in turn calls for more frequent servicing. I would stick with the 6 month, 5,000km. I would not extend it to 10-15k, but thats just me. Im fussy.
Bought some Penrite 10W-40 Everyday plus as it was on special & $1 (almost 6 Yuan worth of savings! :yes:) than GW Syn-X 3000.
Will see how it goes but my initial verdict is: probably would make f**k all difference...
I have noticed that the Penrite Premium 5 (5W-60) runs hotter (operating temp seems to be 90-100°C) than Racing 10 (10W-40, sits around 85-95°C-ish).
It might be the design of the oil, but I definitely need to run an oil cooler.
I noticed the same thing going from Liqui Moly 10w40 to 10w60, I think the extra pressure causes the oil to heat quicker... or something.
I will be going back to a 10w40 next change as 100psi oil pressure cruising at 2500 revs seems excessive. lol.
I asked the question in another thread and it was answered regarding Nulon street and track 15W 50 vs Nulon extreme 10W 60. I usually use the 15W 50. I have a track day coming up and bought more of the street and track. What I don't understand is the difference between the two. In this instance I am obviously wanting to know which would be best for a 25DET, standard internals with bolt ons maing 230ish rwkw. I would like to know about it so I can make my own decision. I have read through here a bit but people tend to use abbreviations and I have no idea what they mean.
15W-50 will be fine. Just monitor your oil temperatures and if you're creeping around 120C maybe look into getting an oil cooler.
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
    • Hi, I need same this wing nismo , Does anyone have one for sale?  if any one have can contact me  00966546888343
    • Nah, lots of insurance repairs on V36 and V37 for pedestrians deployments. Reasons ranging from possums, to extremely severe potholes have deployed them. However, paying for the full repair can still be upto $5k AU some people have noted!
    • Hi, i got 1998 r34 4 door auto abs model and its manual converted with bigbox when i bought it . I successfully find the neutral and reverse light wire but can’t find the speed signal wires for speedo drive. I know its grey plug but on my loom no grey plug with 2 wires . I opened the loom upto where it getting branch with other wire, i’m amazed they is no wire. So need help how to fix the speedometer problem. I search on google it says some r34 model measure speed from diff sensor. Is it right? I talk to a wrecker he say no this isn’t right, i’m kinda stuck. Please help
