  • Replies 268
are you being serrious have you ever been in a rwd with 350rwkw? its alot of fun and none of the fun is happining in a straight line.
No, I'm just regurgitating what someone else said. I've never driven a 350rwkw car. :P
Launching is just so much fun, but whatever you do, dont launch with steering angle applied. Only launch dead straight.
Indeed, I only did AWD donuts twice (didnt require antilag to get it going, just rolled into them and slipped the clutch in 1st). Tyres completely stuffed from a total of about 15 seconds of spinning. Ripped chunks off the outside edge of the falkens it was wearing.
I'd imagine an antilag launch and full lock would stuff the cv's pretty rapidly. They probably just pop instantly.
Be more worried for your front diff :down:
If anyone wants to try it out let me know, i have a spare front diff here for sale!
with a mech diff, 5/7 coils, pineapples, postive camber and 311 rwkw my car stays straight and barely loses any traction on 235 federal 595 ss's and it stays in a straight line
(obviously not in 1st)
As my car is pretty standard atm the launch is incredible, When it does have 300-350awkw it will be an insane experience.
A guy around townsville had a bayside blue 32 GTR with the works. Trust 2.7l stroker twin T518Z turbos, alcons and cage. A few years back he took it out and launched it.... from 10,000rpm lol. it was the most incredible sight i have ever freekin seen in my life
Yeh, the launches are awsome. Years ago the yellow R32GTR from Autostyle ran at EC, it was running 10s all that time ago and the sound of that thing launching. I think it ran a T78, maybe T88. Still one of my favourite cars. The only other thing that has matched it for ferocity was a BD4s built EVO4 that was running an external gate 3037 setup. It was waaaay cool on the limiter launch :ninja:
Hmm yea i remember seeing that thing for the first time in the very first autosalon street car of the year and it was very impressive, it won the comp of course lol
I think one of the most memorable launches i have seen is that purple 2.7l T51R SPL equipped Autostyle R32 GTR with the 19 inch gold Blitz Technospeeds, seeing that thing using Launch Control and Antilag was very impressive to watch
That black one now has the TUFGTR plates. Such an awesome car! Owned by a deadset legend aswel
The yellow one (too fast), still has the winning sticker on the rear window, looks awesome!
Yeh i loved that yellow R32, he wanted 80k or something crazy when i saw it for sale, If it was 30k i think i would actually buy it :(
Oh and Weapon, nice car...but can you make your sig pic smaller? :(
Thats like asking for a penis reduction Roy. :thumbsup::P
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
