lol, evidently he did ;)
Steve and Bernie are using Nagg's R35. Steve has co-driven the car previously.
Rullo just has no luck with that thing..... I do rate how he always seems to keep on smiling though! It does have lots of grunt!
You can get them to over 450kw@wheels in Targa spec.
Keeping them there is a totally different story. I've backed mine right back now to try and keep the thing on the road!
Anyways - for those lucky enough to be there have a great week. It's about now I start to wish I was there again.
haha it chirps 6th!
I figured there must be something wrong in the box to break 2 shafts, but maybe it just does have a lot of go. very impressive for a standard car.
He runs the full MoTeC (M1??) ECU too I think that ignores all the warnings and safety measures the factory computer has that would normally save components of the car as illustrated in the power skid :)
Edited by Darkside
Just had a quick look at some prologue results...for what they are worth.....have a bit of an interest in classic.... Broadbent getting his old RS porkchop around in the same time as Richards GT2RS. That thing of Broadbents must go ok.... 5th outright on the prologue....
Also something about Hendy stopping on Kayena. Was hanging my hat on him for EM victory.... Be gutted if he cops a snot time so early in the piece.
Ah that explains why I couldn't find Tim's result.
Fingers crossed he get's away with it - but it almost looks like Day 0 counts this year? Can anyone confirm if these 2 stages are more than just a shake-down / seeding procedure this year?
I presume not because there are some weird / slow results from guys you'd expect on the pace in all categories.
lol that would be funny to watch. to be honest I think they'd be better to focus on making the event affordable to get the volume of competitors up; the start time list has only 177 cars.
good luck today for everyone lucky enough to be there!
Is this the best updates page? http://www.targa.com.au/tc/page_full.asp?asset_id=8653
Not much happening...although it seems Rullo's tailshaft issue are getting worse not better
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
