Slightly OT - are you doing Sport GT @ Phillip Island again Ben?
I entered it this week.
I'd like to, but can't really afford to do PI and Targa. Never say never though, it was a great event
I tell you for the cost of entry ($1200) and the amount of track time you get I don't know of any other category that gets full live TV coverage for the price.
Chris (Scotsman) has also entered in his R33 GT-R. I'm looking forwards to it even though I know my thing will be totally uncompetitive in that field.
  • 3 weeks later...
The most impressive part of that video is Adam is driving around in a t-shirt.
When do you ever get to drive around on the track in a t-shirt in this country!!?
We used to do it all the time in Tassie, until about 18 months ago when CAMS clamped down on private days. Didn't you know that fire burns colder when your practicing.
  • 7 months later...
Thought it was time to bump this thread up. The 25th Targa Tasmania is only 3 weeks away now and it looks like a big field.
I'm giving the Skyline a rest this year and moving over to the dark side. I'm going to be running Dad's old Subie in the new GT4 class.
Is anyone else running or coming down for a look?
12768341_1075374549201205_61409485251037
Edited by sav man
  • Like 2
Looking good Ben! I'm sure you'll smash the 35s in gt4. Should be easy to drive in the wet. Kind hoping we get a wet day somewhere to mix it up (and so my tyres can last).
I'm almost ready to go, only a few small jobs left then on the boat in two weeks. Don't know how I feel about the new car number 747.
  • Like 1
I think the 35's will struggle with the GT4 regs and the heavy service restrictions this year. I will be interested to see how fast Quinny is in his Lambo. I will be sporting some Nissan though, I'm running R34 GT-R
Nothing wrong with 747's
Yeah they will be quite heavy. Probably fine in the wet just slower and heavier tyre wear everywhere else. How does it feel to drive after the skyline? Less driver input needed?
Went to bleed the alsd this afternoon and the bleed nipple on top snapped off... Have since picked up a very fresh looking asld to put back in. Good thing it's a long weekend.
They are pretty different. They are all about low down torque and corner speed compared to a skyline, chassis development has come a long way in 20 years. Over a stage the Subie would be faster I recon
Shame did thread kind of died in the arse - FB has a lot to answer for.
See you there gents. I'm servicing for the first time ever this year, will be great to see the event from that perspective.
It's going to be a great year, I'm sure the organisers have a bunch of cool things organized :)
Good luck to you all!
You with Adam Clarke?
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
